Will My Heads work with a TPI Base? HELP!!!!!!!!!!!!!!
Old Oct 5, 2001 | 01:39 AM
TexasZ28's Avatar
I Recently bought a 305 TPI from a friend and I have a 350 carbed moter in my car.It looks as if the bolts on the TPI base are the same angle as my original manifold..will the work? PLEASE HELP!!!!!!!!!!!!
If it's too Loud or too Fast yer too OLD!!!
Old Oct 5, 2001 | 04:18 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Sounds like the setup you got was off an 85 or an 86, yep will work a-ok.
Even if the angles were different, you could grind the holes out to match.
One thing to watch is if the setup is out of an 85 and you have the 85 computer, it may be a wise idea to upgrade to the later computer with the AJUN or ARAP code. If you go with the ARAP you have to diable VATS. The 86 code could be buggy and the piggyback MAF setup of the 85 is a real PIA if it ever fails.
[This message has been edited by JoelOl75 (edited October 05, 2001).]
1992rs/ss
Jan 31, 2025 05:10 PM
Vintageracer
Jan 10, 2020 05:33 PM
89-S-dime
Aug 12, 2015 11:57 AM
squiggy2
Aug 9, 2015 09:30 PM
Fronzizzle
Aug 9, 2015 01:15 PM
