Build-up let me know if this will fly or not (I have ZERO experience so be nice)
Old Oct 5, 2001 | 04:24 PM
Drakar's Avatar
Ok I will try and give as much info as I can let you all know what my goals are so I can get the best advice you guys have to offer.
89 L98 stock bottom
L98 cam w/t 1.6 RR
Speed-pro forged pistons 10.4 CR with below heads.
AFR195CC heads 74cc w/t heat riser (emission)
- 2.02 intake
- 1.60 exhaust
stock intake (ported & polished)
SLP Runners (ported & polished)
stock plenum (ported & polished)
52mm Holley TB
SLP 1 3/4 headers into dual 2.5"
I have left lots out (cause I don't know what else I can change or should)
but I'm looking for 300rwhp and anywhere from 350-400 rwtq, also I want peak power between 5200-5800 rpm.
And from what I have read stock maf should support that Y/N???
I might/eventually switch to SD but that would be later.
1989 Trans Am GTA - Flame Red Metallic, L98 5.7L TPI, TH700-R4, T-Tops, 3.27, 9-bolt rear, dual cat
- K&N Air & Oil Filter
- Dynomax muffler
1992 Camaro RS - Hawaiian Orchid, LO3 5.0L TBI, T-5, T-Tops, 3.08, 10-bolt rear - Sold
- L69 Dual Snorkel
[This message has been edited by Drakar (edited October 05, 2001).]
Old Oct 5, 2001 | 08:29 PM
Guest
Guest
Posts: n/a
Youve got a mismatch waiting to happen going on here. I'd recommend changing the cam, using 190 heads not 195's, and the stock intake base isnt going to help things any. Other than that it looks ok. And forget about making peak power at 5200-5800 unless you plan on going miniram or *maybe* superram.
I wouldnt worry about the MAF right now it should support that just fine.
Old Oct 6, 2001 | 09:03 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Definatly need alot more cam to take advantage of them heads and that compression.
Old Oct 6, 2001 | 09:37 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Yeah, you'd be better off running *at least* something like the LT4 hot cam (218/226) and 190s w/ an aftermarket base. Much more matched.
Old Oct 6, 2001 | 10:10 AM
airdeano's Avatar
ditto on ed's comments...
all that compression and nothing to get into
the combustion chambers. the cam/manifold is
starving this setup.
Old Oct 6, 2001 | 06:59 PM
Drakar's Avatar
so goign with what Ed said, and expecting to have peak power between what 4700-5300rpm.
what ill effects will this have on emissions?
I have to pass slighty easier then CA, and only sniffer no visual (except if the cat is still there) and I do still have my cats working.
should I still go for it or would I just be spending money to fail???
- Dynomax muffler
- L69 Dual Snorkel
F-body-fan
Nov 4, 2015 06:13 AM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
Mongoose462ci
Sep 16, 2015 11:46 PM
cstrobel65
Sep 16, 2015 11:54 AM
dimented24x7
Sep 6, 2015 03:51 PM
