Ram-jet
Old Apr 21, 2008 | 01:57 PM
BadAz_Iroc's Avatar
Ram-jet
Does anyone know if you can buy just a Ram-Jet intake system without the whole motor, i seen the intake but it alwsy on a creat engine.
Old Apr 21, 2008 | 03:25 PM
S10Wildside's Avatar
Re: Ram-jet
Absolutely. Check out this thread.
https://www.thirdgen.org/forums/tpi/...tml?highlight=
Old Apr 21, 2008 | 04:00 PM
BadAz_Iroc's Avatar
Re: Ram-jet
hey thanks, Where do i order it from, and is it the same cost as the HSR, I like both but if i can get the Ram jet for the same price i am going with GM all the way.
Old Apr 21, 2008 | 05:04 PM
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
Re: Ram-jet
I kept watching ebay and got lucky by just buying the intake, fuel rails, and throttle body for 750.00.
I just searched every day for about 4 months. Heh, it saved me money, and you don't need the rest in thirdgens.
S10Wildside made me a OBDII harness, and I'm using a 0411 PCM. Check out this thread https://www.thirdgen.org/forums/tpi/...-opinions.html
Old Apr 21, 2008 | 07:59 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
Re: Ram-jet
I bought my intake from GMPartsDirect. Got an LS1 throttle body, and Edelbrock fuel rails which are only $80, quite a bit cheaper than the GM ones.
The Stealth Ram will be cheaper, unless you find a great deal. Try and find a complete one. The nuts and bolts and little stuff is what starts to add up. The 2 piece throttle bracket is $60+, the MAP bracket is $30!!!!
The sensors are available on other GM vehicles. I got my harness ends to convert my '730 at a junkyard for free.
I still ended up spending $125 or so on stupid little parts that I couldn't find else where.
Don't forget you need to use Vortec/Fastburn style heads. It won't bolt up to the stock heads.
APACHE JOHN
Aug 20, 2008 08:25 PM
APACHE JOHN
Alternative Port EFI Intakes
Aug 8, 2008 08:55 AM
bad_turbo
Sep 3, 2003 05:51 AM
SQUIRLEYMOFO
Nov 5, 2002 06:42 AM
drain89
Nov 16, 2000 11:12 PM
