running problems
Car: 89 camaro rs
running problems
i have a 91 z28 305 tpi....and it starts up and runs for like 4 seconds then dies...changed the map sensor...fuel pump is new...could the fuel filter be causing this or the fuel pressure regulator???
Re: running problems
Yes. So could the ECM, a grounding injector, HEI module, and numerous other things. A little more information is needed. Connect a fuel pressure tester to see if pressure remains after the engine stalls.
Car: 89 camaro rs
will do....and how would i be able to check if any of those are the problem...i mean if i did a diagnostics on it...will it tell me the codes of whats all wrong
Car: 89 camaro rs
anybody in to toledo area please help me....im about to sell this car cuz im tired of dumpin money in it and it not runnin....if anyone can help please let me know. 329 0513 if you can come check it out for a few
theshackle
Mar 5, 2017 06:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
db057
Aug 11, 2015 10:11 PM
