Valve seal questions....
Old Apr 21, 2008 | 05:22 PM
Parts4sale's Avatar
i have a set of 187 and 416 heads why don't they have exhaust valve seals?
or did they just burn off or did GM not put seals on the exhaust side?
2nd i just got done installing springs locks and seals, i was setting the vavle lash
and the seals where squeaking really bad, I remember i forgot to oil the valve steams after i installed the seals is there anyway they could pull out? i tried right away to shoot some oil between the springs and finished up my valve lash and getting the engine back to TDC - is there anyway the seals would pop off?????
Old Apr 21, 2008 | 10:13 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
Re: Valve seal questions....
exhaust side shouldve had umbrella seals. did you soak the seals in oil or dip them in oil at least before you put them on? if so thatll lubricate them enough.
Old Apr 21, 2008 | 10:46 PM
Parts4sale's Avatar
ya i used a can of oil i just poured some oil in the cap and dipped the seals in there for each one i used the tool it came with to slip them past the lock grove and o-ring grove so oil hardy got on the steam i didnt think about it till after i started turing the blancer to set the lash i heard some squeking and stop oiled them i didnt see anything on the sheet with the seals i got about oiling the steams but i should be fine then viper?
Bubbajones_ya
Jul 6, 2024 08:32 PM
355tpipickup
Sep 13, 2015 11:35 PM
bamaboy0323
Sep 12, 2015 07:14 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
tgp1990
Sep 4, 2015 06:24 AM
