dont know what board
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
i sold my ride and am looking into a new one but what to do. know it's gonna be a roc for one.the lt1 intake to a gen 1 block got me thinking!could the lt1 be ran with the 3rd gen equipment?if you drill the whole for the distributor(using the small distributor) and drill and tap the waterpump housing for the intake temp sensors and use the head sensors and knock sensor from the tpi unit the ecm shouldn't think anything is different.that way the waterpump could still be used reverse flow and all.i even think the 3rd gen accesories could be used if a bracket is made to mount a pulley back in it's original place of the water pump(kind of like the a/c delete pulley.all answers are welcome and needed.dont be shy on this one guys need suggestions.also does anyone know if the front timing/waterpump cover will bolt up to a 3rd gen block the ouline kinda looks the same.thanx
87 trans am,gm crate 350(4 bolt mains 10to1),L98 aluminum heads,LT4 hot cam,slp runners,slp 1 5/8 headers,3in.y-pipe,edelbrock base,hi flo cat,air foil,afpr,as&m ported plenum,gutted airbox,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ed wright's fastchip,relocated iat sensor,160 fan switch&t-stat,tb bypass,accel supercoil,cap& rotor,slp 3in. catbcak,a/c delete.
SHE IS GONE BUT I KNOW THE GUY WILL GIVE HER A GOOD HOME.
best e/t:
3653lbs./full tank+ driver.
14.10@96.53mph 2.01 60'
best e/t:
Car: 1989 TTA #1240
Transmission: 2004r
c'mon guys no suggestions?need info.
best e/t:
best e/t:
I was told that the angels of the gasket surfaces were different. But you might want to do a search on the LT1 Intake because there was a good size discussion on this about a month ago.
89 Iroc 350 TPI,
Forged pistions
Comp roller Cam .510 lift 230dur
Flowmaster exhaust
Dart Iron Eagle heads 200cc runners 64cc chambers
MINI RAM SOON!!!!!
stock TPI for now 24# inj
87 Trans Am GTA 350 TPI
had engine fire
SHE NOW RUNS!!!! GREAT!!
Flowmaster exhaust
LT1 Injectors
89 Iroc 350 TPI,
Forged pistions
Flowmaster exhaust
MINI RAM SOON!!!!!
had engine fire
Flowmaster exhaust
LT1 Injectors
Did you miss John Millican's post entirely? Look for his post, the one with 23859762389523 posts(ok maybe not that many
), but he did just that and he's the one to answer your questions?
Brendan
), but he did just that and he's the one to answer your questions?Brendan
Car: 1989 TTA #1240
Transmission: 2004r
did you happen to read the second line of my topic?it says"the lt1 intake to a gen 1 block got me thinking"i read his posts as well as many others an looks like a great alternative i am asking if the complete 2nd gen lt1 motor can be controlled by the 3rd gens harness and ecm?hey but thanks for replying to something you've obviously missed.any seriously knowledable people out there that could shed some light on this?thanx in advance guys.
best e/t:
best e/t:
A few years ago I saw a LT1 intake on a 350. The guy drilled a hole for the distributor and I think he had to make a coolant passage along the rear of the manifold. I didn't get a good look...I was a bit excited about my Typhoon (All Wheel Drive) drivetrain purchase at the time.
All I can say is that it's possible.
1982 S-10 Wildside
355 TPI, Accel High-Flow Intake, Ported Plenum, Arizona Speed & Marine Runners, TPIS AFPR, Edelbrock BBK 52MM Throttle Body, Sanderson Ceramic Coated Headers 1993 Typhoon Drivetrain
1982 S-10 Wildside
Elephantismo
Feb 13, 2019 12:51 AM
Linson
Oct 1, 2015 09:50 PM
