how do i adjust the t/v cable?
Old Oct 8, 2001 | 12:20 PM
i8urrice's Avatar
my car shifts out of first too quickly.....how do i adjust that tv cable, i don't want to break it.
88 Trans Am, 5.0L TPI, flowmaster cat back, high flow cat, WS-6 performance suspension, black w/ t-tops, automatic transmission....soon to be armed w/ a 5.7 TPI
Old Oct 8, 2001 | 12:37 PM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
You need a screwdriver and a friend. First you open your hood. The TV cable is located right below the throttle cable. It has a button on the side. Pushing in this button adjusts the cable length. Your main goal is to make the cable guitar string tight at WOT. With the engine off, disconnect the cable and press the button on the side of the TV cable, make the cable housing "longer" by backing it out of the bracket (not too far). Let the button go. Re-attatch the cable and have a friend press the gas to the floor. The cable housing should ratchet out a little, and the tension in the cable itself should be guitar string tight. Play around with the housing through the bracket length to make it shift earlier or later. Test the shift points at part throttle. Somebody else here might know where it is supposed to shift at.
355 c.i.
Dart 180 Heads
Lunati 224/224 cam
Harland Sharp 1.5 rockers
Performer RPM Manifold
Holley 600 cfm double pumper
Hooker Super Competition Headers
Flowmaster Exhaust
Competition Engineering Sub-frame connectors
Super T-10
GM posi 3.42 rear
Hurst Roll Control
13.9@102
Old Oct 8, 2001 | 04:09 PM
Kyle F's Avatar
Shift points is another thing that can be adjusted for best performance. I personally like to have the shift points higher while on the street because the kick down is better. Like it will kick down at 1/2 throttle and not fall into OD as early.
Though at the track it has been proven that a stock TPI runs better sifting at 4200RPMs. Though this changes with mods to the intake runners/cam/heads bla bla bla.
Its personal preference on the street and what gives you best times at the track.
89 Trans Am Turbo 3.8L All stock 43,000 miles #1053 of 1555
Past Thirdgen:
86 Trans Am w/ built 355TPI with SLP goodies and too much other stuff to List. One sweet *** car, wish I would have had a good enough Job to pay insurance on three cars so I could keep it, but for a 89 Turbo Trans Am w/ Low miles, I think I made the right choice!
88SS6SPEED
Nov 11, 2015 07:05 AM
WejaZ28
Oct 3, 2015 07:38 PM
corey8084
Brakes
Sep 15, 2015 08:14 PM
SG91camaro
Sep 5, 2015 10:27 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
