Please Help me...Loads of fuel smoke
Old Apr 22, 2008 | 05:36 PM
pa_richardson's Avatar
I have posted this problem before with no luck..
TPI 5.7 Speed Density..
Th engine starts okay but puffs loads of smoke then will stall if you let it idle.
Its does this from cold.
New Ecm, Iac, Temp sensor, ignition module,plugs,leads,cap,fuel,oil,Map and Fuel Regulator,cleaned injectors and throttle body,checked all vacum pipes.
The engine was put in an Astro van in 1995 and has never had an o2 or all the emmisions system connected it has no cat.
PLEASE PLEASE help me i really got to get this running now.
Thank you guys......
Old Apr 25, 2008 | 03:57 PM
Re: Please Help me...Loads of fuel smoke
Come on guys any ideas?
Old Apr 25, 2008 | 04:12 PM
mario82z28's Avatar
Car: 82' z28/03' eddie bauer explorer
Engine: 355-395hp/4.6v8
Transmission: Built 700R4/5speed auto 4x4
Axle/Gears: 3.42LSD/3.73
Have you tried the air fuel regulator or see how much psi your pump is pushing
Old Apr 25, 2008 | 10:06 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
What color is the smoke? If it's really fuel, I'd suspect a bad injector. How did you clean them? We're they checked for leak down?
Old Apr 26, 2008 | 03:57 PM
The smoke is very dark andis there from the very moment its started..I have checked and changed the fuel regulator...I removed the injector rail and pressurised the rail with he fuelpump and looked for leaks and gently dabbed the bottom of the injectors with a cloth they were dry..I then went on to having them sonic cleaned just to be sure it made no difference.
I have only checked and adjusted the fuel regulator just of the fuelpump priming it read 46psi and stayed there forawhile slowly dropping of given time...Should i have checked the rail with engine running?
Man this engine is just laughing at me....
Old Apr 27, 2008 | 12:41 PM
I have just spotted the pick up coil is damaged and very rusty i will replace this and see what happens..
Old May 26, 2008 | 04:50 PM
Okay i sorted it i was looking in wrong place turned out to be the pick up coil once changed the smoke went away and engine runs better than ever...
Thanks for all you help
chazman
Aug 28, 2018 03:25 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
dyeager535
Aug 28, 2015 08:10 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
chazman
Aug 22, 2015 02:01 PM
