plug behind distributor
Old Oct 6, 2001 | 06:51 PM
Psyte's Avatar
Car: 1989 Trans Am GTA
Engine: 5.7L 600cfm carb
Transmission: 700R4 (auto)
hey, just recently ive had my heads re done and have completed the big *** job of putting everything back together. but unfortunatly there is one plug that is on a short wire behind the distributor that i just cant figure out where it plugs into. it cant go very far and ive inspected just about everything and every socket has a plug.... can someone please help me with this? i got an 89 T/A GTA
Old Oct 6, 2001 | 07:55 PM
JETHROIROC's Avatar
It's probably the EGR solenoid hookup, but did you plug the two connectors into the distributor?
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, MSD coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Accel 23# injectors, Holley module, ported plenum,
Ported Daytona Yellow stock base, Moroso valve covers, other stuff,
Streetdampr, Ruger P95DC, hot wife, new oil filter, !cats, !TBC, !AIR.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
Old Oct 7, 2001 | 02:48 AM
89Irocz23's Avatar
is it maybe your plug for your MAT. The sensor that is in ur plenium. its kinda in front of the distributor, but inside the TPI
Old Oct 7, 2001 | 07:35 AM
Psyte's Avatar
well, from what i can tell, every plug is in its proper place. there was a really hard to get one near the distributor under the rear part of the upper plenum. but i still cant figure out what that one behind the distributor goes to. after all my work the car still isnt running good. it chugs, smoke comes out of the exahst, and it will die if i dont keep my foot on the gas. i get a code 32 which means some EGR screw up. would this be the cause of haveing no pipes screwed on to the exhaust manifold's? basicaly the exahaust comes straight out of the engine. would my car be running so rough because of that? or could it be the timeing? its a possibility that i didnt have the distributor pointing in the right direction, but i couldnt help it cause it wouldnt slide back into the original slot.
Old Oct 7, 2001 | 08:39 AM
JETHROIROC's Avatar
As I said, it's the EGR solenoid most liekly. It attaches to the same bracket as the ignition coil.
Old Oct 8, 2001 | 09:49 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
The EGR sol. has a two wire female connector with posts inside, and green insulation.
Is that what this looks like?
There is also a sensor at the bottomside of the plenum that measures air temp. Is that not plugged in?
EGR doesn't matter. I couldn't see a difference with mine plugged/unplugged.
You SHOULD check your timing. I'm running super advanced, but if your running retarded you'll chug, smoke, backfire, etc.
Describe the connector better and we'll tell ya what it is.. I just finished building my 355 TPI motor in a 89 body so I'm very familiar with all the connectors now, and how close they can and can't be to the headers ;(
-- Joe
1989 Formula 350 4-bolt mains, Forged .030 TRW pistons, SLP 51010 Roller Cam, World Products Sportsman II 2.02/1.60 heads
Edelbrock TPI Intake
24lbs/hr Injectors
Cloyes Double Roller timing chain, Comp Cams roller lifters: 13.86 @ 99.88 MPH
-- Joe
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
