Selling my stock TPI setup on e-bay. How much should I ask?
Car: 2004 GTO
I have the plenum,runners,throttle body,manifold and I'll throw in a set of Bosch 24# injectors.
Any idea?
Any idea?
Car: 89 IrocZ
Engine: L98-ish
So this isn't a complete setup then? Just what you listed?
You may be better off jus selling in the classified.
Lower intake 50-60 bucks,plenum 40-50 ucks, runners 30-40 bucks, TB 40-50 bucks...injectors no idea.
In one package EBay may bid about 130-150 bucks.
I'd suggest auctioning off one at a time, or listing in the classifieds at thirdgen.org
Consider you can buy a complete setup (fuel rails, harness, ECM, distributor, etc) in the classified for 350-500.
I got as much as 300 dollars for a complete TPI setup w/out the harness or ECM.
1991 Z28 6.0 TPI
360 4 bolt main block, TrickFlow 23 degree heads, CompCams CS270HR cam, Harland Sharp roller rockers, Accel base, SLP siamesed runners, 52MM SLP Throttle Body, Hooker Headers, Flowmaster catback, MSD6A ignition, Home made ramair system, 2500 stall, bullet proof 700R4, aluminum driveshaft...
1991 Z28 6.0 TPI
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
For a while I was getting 300-350 for complete setups with harness and ECM.
I sell the harness's for 125.00 alone.
Most people now don't buy stock TPI stuff, unless they're looking for a base to tune with.. The aftermarket stuff is coming down.
A friend of mine has gotten as much as 200.00
for just the baseplate up, with 22lbs injectors.
-- Joe
-- Joe
Sanjay
Aug 12, 2015 03:41 PM
