Started Polishing and porting intake... questions
Old Oct 9, 2001 | 06:32 PM
Ions91Z28's Avatar
Car: 1991 Camaro Z28
I mainly started polishing. I've been sadning with some dremel 60 grit sanding drums to rip the cast off as possible. From there I'll hand sand unless someone knows a better way. However, how do I get in the small cracks and hard to reach places?
As for porting, I'll be using a dremel, I don't have access to a air compressor so die grinder is not possible. I bought a Tungsten Carbide Cutter... will this work?
91 Z28
Best Time Slip:
60' - 2.098
1/8 - 9.137 , MPH - 76.21
1/4 - 14.213, MPH - 97.55
Performace Mods: B&B Exhaust, few free mods.
Appearance Mods: SS wheels, 2.5" Cowl Hood... New 100% Black paint job, Clear Side Marker Lights
Stereo: Alpine 855, Infinity Kappas all around, Infinity 150x2 amp (POS), Infinity Perfect 10 in hatch.
Pictures are Here
ICQ: 1437212
AOL: normalmatt9
Old Oct 9, 2001 | 07:02 PM
Ions91Z28's Avatar
also, there used to be links about porting plenums. And a PDF file. Those links are now broken, are they somewhere else now? IF there is any more information about porting an intake you can give me please do... like how to measure certain parts... and how to avoid going through the intake.
91 Z28
Best Time Slip:
60' - 2.098
Pictures are Here
ICQ: 1437212
AOL: normalmatt9
Old Oct 9, 2001 | 07:11 PM
Ions91Z28's Avatar
I'm good at replying to my own thread...
Here is the type of stone I bought to port the intake.
Will this work?
http://cgi.ebay.com/aw-cgi/eBayISAPI...tem=1282669067
91 Z28
Best Time Slip:
60' - 2.098
Pictures are Here
ICQ: 1437212
AOL: normalmatt9
Old Oct 9, 2001 | 08:18 PM
JETHROIROC's Avatar
That will work, but a $5 HSS bit is just as good or better at eating aluminum up and it won't clog easily with chips unless you overheat it. I can't really comment on the polishing though.
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, MSD coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Accel 23# injectors, Holley module, ported plenum,
Ported Daytona Yellow stock base, Moroso valve covers, other stuff,
Streetdampr, Ruger P95DC, hot wife, new oil filter, !cats, !TBC, !AIR.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
Old Oct 9, 2001 | 08:41 PM
Ions91Z28's Avatar
Okay, I've learned what HSS is.... Can you give me any tips on what diameter I should buy them in?
[This message has been edited by Ions91Z28 (edited October 09, 2001).]
Frozer!!!
Jan 19, 2024 04:55 PM
kah992
Aug 19, 2015 02:55 PM
redmaroz
Aug 16, 2015 11:40 PM
mx127
Aug 10, 2015 08:13 AM
92projectcamaro
Aug 6, 2015 01:20 PM
