quick air induction question
Old Oct 11, 2001 | 02:22 PM
chevyboy07 91's Avatar
Is having a K&N filter mounted at the TB better than the factory "ram air" set-up? I have the TB mounted filter and I know it's just sucking up hot air....but I think it's still getting more air than the factory set-up. Am I right?
Alex A. (aka chevyboy)
1992 Z-28 L98/1LE. Heritage Edition. SLP runners, gutted cats, SLP 3" cat-back & muffler. 3" flo-tech cut-out, SLP TB foil, K&N filter @ TB, 3.23 posi rear.
Old Oct 11, 2001 | 04:36 PM
Lounge Lizard 6's Avatar
IMO flow differences are probably negligible but air temp would be significant.
Mike
'90 IROC-Z , 5-speed, ZZ4, G1 Trick Flows
Moderator SEThirdgen
Old Oct 11, 2001 | 04:41 PM
The AntiModerator's Avatar
If you are looking for hard numbers on this topic, you might be hard pressed to find them. Most people don't use the TB mounted K&N's because of that exact reason. If you still have the Z-28 cold air induction (draws air from in front of the radiator) I would put that back on.
A clean set of stock filters inhaling cold air is better than a high flow filter inhaling hot air.
Old Oct 11, 2001 | 04:46 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Folks have run 10s through the stock camaro TPI snorkel... exactly how much more air do you need?
Old Oct 11, 2001 | 04:49 PM
Try this:
http://exit3.i-55.com/~davidlt/air_intake.htm
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
kyle5647
Aug 15, 2015 11:56 PM
happyhapka
Aug 15, 2015 04:42 PM
