Project 450 hp 305 TPI not going well :(
Old Oct 10, 2001 | 06:32 PM
vortech305's Avatar
For some reason after we get done fixing a problem some other arises. We got done installing the motor on the 92' camaro we cut the hole for the t-5 to go in, yet we find annoying problems, Why are TPI's so freakin annoying and confusing, I bought a junked 87' 305 TPI motor with 87' Computer, Is an 89 305 TPI engine harness compatible with the 87' TPI, both motors where 305 TPI 5 speeds.
Old Oct 10, 2001 | 07:23 PM
irocbsa's Avatar
It should be basically the same. Both are MAF harnesses. I'm trying to think of differences between 87 and 89.........no cold start injector(?), can't think of anything else.
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI, Converted to SD, 700R4, B&M Megashifter, 3.42, Trick Flow Twisted Wedge Heads, Edelbrock Intake, Accel Runners, Comp Cam, Crane Gold rockers, Lucas 24# injectors, Edelbrock headers, Flowmaster 3'' exhaust, Mallory Ignition, Shift Kit, Corvette Servo, 2,000 Stall Torque Converter
1991 RS, 305 TBI, T-5, Bone stock daily driver.
Old Oct 10, 2001 | 10:40 PM
james_fearn's Avatar
I think some sensors and relays *may* are different. I seem to recall the the relays use a different connector, i.e. the 87 has the square type and the 89 takes an oval type. They may also take different distributors, big cap vs. small cap. I also think 87 was v-belt based while the 89 is serpentine. Looking at the difference in the junkyard the serpentine has a totally different air injection converter/diverter system that may mean the wres are of different lengths and have different connectors.
James
Old Oct 11, 2001 | 01:32 PM
vortech305's Avatar
great more bad news
Old Oct 12, 2001 | 12:28 AM
airdeano's Avatar
why not use the stock harness with the car.
the 87 isnt any more or less than the 89.
the 89 worked once before the swap. the differences
are yes the cold start injector(9th inj)
MAF i believe is different.
just use the cars harness and computer.
plug off the CSI and start it up.
was the 92 a TBI car?
high pressure pump in the tank?
airdeano
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
