Plenum and runner compatibility
Old Oct 11, 2001 | 02:35 PM
wpowers's Avatar
I was thinking of buying a plenum and runners off of ebay and porting them,this way I would not have as much down time on my car and could take my time.My question is which years are compatible.I have a 88 350 Iroc.Thanks
Old Oct 11, 2001 | 03:18 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
If I remember correctly the runners are the same. I could be wrong though. As for the Plenum, you will need one from an 85-89. You are most likely running a MAF setup. 90-92 use speed density. Good luck.
Hope that helps!
'91 Z-28 5.7, SLP 1 3/4 headers, 4 inch Mufflex/Flowmaster cat back, gutted cats, Edelbrock intake, 8.5mm Jacob wires, MSD Blaster coil, S&W subframe setup, Jacob Pro Street Ignition, complete Kenwood system.
Old Oct 11, 2001 | 04:14 PM
The AntiModerator's Avatar
An 89 plenum has no provisions for a cold-start injector. Also, in 1989, they removed the recess for the IAC passage behind the throttle body. I think you might be stuck with the 87-88 plenum if you want to keep it stock.
Old Oct 12, 2001 | 02:00 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Any 85-88 plenum, runners, and throttle body will interchange with your 88 setup.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
Linson
Oct 24, 2025 02:00 PM
toronto formula
19
Oct 6, 2015 12:27 PM
Royal_Z
Sep 30, 2015 08:45 PM
