ATTN: 305 TPIs and 5 speeds
What is your car running at the track and what mods did you do to your car?
1987 Black 305 TPI 5spd IROC, seems to be fully loaded, but can't find RPO codes.
AIM: IROC 5spd
http://www.geocities.com/chevy5spdiroc/87Roc.htm
AIM: IROC 5spd
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
89 GTA 305TPI 5speed, The best i ran was a 15.11 at 93.65 mph (should've been closer to a 14.8 if i knew how to drive). edelbrock headers, highflow-cat, flowmaster on stock cat-back, al driveshaft, also ported plenum, coolant bypass(not that these gain anything). I hope to go again soon (next weekend) with a SLP chip and some sort of coldair.
<font face="Verdana, Arial" size="2">Originally posted by camaro6spd:
</font>
</font>
Bugs
91 Z28 305TPI 5spd
Hypertech Stage II, EB Intake & Runners, Ported Plenum, EB Headers, 3" Cat, 3" FM Catback, 1.6RR's, 3.42gears, B&M Ripper Shifter, MSD Wires/Cap/Rotor/6AL, AFPR, Air Foil, K&N's, Gutted Airbox, TB Bypass, platinum plugs, and 160deg Stat.
When I had my car I ran a 14.1 It was a 91 Formula. I had the heads ported with a three angle valve job. Competition cam. Edelbrock headers and flowmaster exhaust. I had a bunch of other things done to it too. Msd 6a,custom chip,hurst shifter,k@n, the kid who has it now ran a 14.6 but then burned up the clutch and tranny.
[This message has been edited by formula14 (edited October 04, 2001).]
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
My times and mods are in my sig, and my car has 110,000 miles on it.
1988 Formula 5L/5sp 3.45 gears, SLP cold air kit, MAS gutted, TPIS air foil, TPIS AFPR, MAC headers, Mac under drive pulleys, MAC cat back, Relocated MAT.
Best ET street tires 13.85
Best 60 FT street tires 1.930
Best MPH street tires 99.29
My best times are in the sig.. I had all the mods on the 305 except the headers be4 i spun a bearing on it. I bet i could have ran in the 13's with the headers on the 305.
88 IROC-Z 350 TPI 5 speed
Performance Resource Chip, Flowmaster American Thunder cat back exhaust, B&M Ripper shifter, MSD coil, TB bypass, TPIS MAT relocation kit , AC Delco 160* t-stat, Richmond 3.73 gears, March Power & Amp pullies, Home made Ram Air, Steve Spohn SFC's, LCA's, and LCA relocation brackets , Panhard bar, TPIS AFPR, Ported plenum by Daniel Burk, Mac Test pipe
Best et: 14.232(all times with 305)
Best mph: 97.76
Best 60': 2.063
http://hometown.aol.com/famioso15/johnnyiroc.html
Best mph: 97.76
Best 60': 2.063
Car: 87 IROC
Engine: 305 TPI going to LT1
Transmission: 5spd
14.43 @ 96 with a 2.16 60 ft
no cat, no smog, hooker comp. ceramic coated shorty headers, custom 3 inch y-pipe, stock cat back system with a flowmaster muffler, ported plenum, ported intake base and siamesed into the base 1.5in.
i probably should have ran more like a 14.3x but i did something different to my spark plugs to try to get a better spark but i think it hurt me.
i'm hopin for 14.2 with new plugs and a cutout. it all depends on if i can stick my car or not
Andrew
Andrew
Car: 87 IROC
Transmission: 5spd
the stock exhaust is a 3 inch cat back
no they aren't overkill they are the 1(5/8) primaries.
and they aren't super comps just competition headers but they are ceramic coated
i love them they were the best mod i did for my car
plus my car is not smog legal, we dont have to worry about that here in Oklahoma
we don't even have inspections anymore
Andrew
Andrew
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
The numbers in my post are actual drag strip times. The times from my G-tech are faster then then my actual times. The G-tech reads 13.60's at 104 MPH. My G-tech (for reasons unknow to me) will usually read 2-tenth faster then what the car actually runs.
Engine: LS7
My G-Tech never read very acurate and now that i'm at school in FL the track is only an hr away, i'll just go there and get some real times. I wasn't too happy spending $140 on the G-Tech.
Um Zepher, that's not a 4thgen spoiler, its a '91-'92 WS6 spoiler. nice chicks
-Tas
'89 Formula WS-6
305, TBI, 700R4, P.A.W. 14x3 open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips, Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248)
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Got Beach?
-Tas
'89 Formula WS-6
Super GRK_Taz World
F-Body Dual Exaust
AOL IM: superGRtaz
Got Beach?
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Just got back from the track today 14.94 @ 92 mph.
TBI converted to TPI w/TRW cam 198/210 @ .050 .450/.460 114 LSA Stock manifolds single 3" cat back 3:45 9-bolt stock runners and base & TB.
Chronologically challenged. But still kicking!
'92 CAMARO RS
305 TBI 5/spd (now TPI)
B4C Alt.
'69 camaro-BB/Lenco,1050 dominators, /Pump Gas/no drugs 8.97-150+/3200lbs.
SoCal Thirdgen F-Bodies
'92 CAMARO RS
B4C Alt.
Mods and times in my sig.
Shooting for some 13.90s with the 305
, before the 383 goes in.
91 B4C 305 TPI - SOON TO BE 383
TREMEC 5-SP, STOCK 1-BOLT REAREAND w/342 GEARS, K&N, AIRFOIL
EDELBROCK HEADERS, DUAL CAT TO HOMEMADE Y-PIPE & 3.5" SINGLE PIPE W/ FLOWMASTER, CRANK PULLEY, MSD, FUEL PRESS REG, COWL HOOD, WELD WHEELS
14.1@ 98MPH
OTHER RIDE
67 CAMARO - STREET CAR, BIG BLOCK, PUMP GAS
350TH w/ATI 10", 12-BOLT w/373 GEARS
10.47@129 1.55 60FT. ON MOTOR - ET-STREETs w/MUFFLERS
, before the 383 goes in.------------------
14.1@ 98MPH
OTHER RIDE
Car: 1990 Iroc/Z
Engine: LB9 305 TPI
Transmission: Borg Warner 5 speed
there's a whole bunch of crap in there like exterior mods, but the engine and computer mods, the 14.7 was made on an Ed Wright stage 2, gutted cats (G92), and adjustable fuel pressure regulator. I had the Hi-jacker air shocks pumped up to 50lbs for a better "squat" off the launch. And things like the MSD ignition and coil if that even adds HP I sincerely doubt. I don't know if my web-page still works or not, but if it does, it's at: http://php.iupui.edu/~balyea
Modifications list on my Iroc:
Engine Specifications and Relevant Information
Displacement: 305 Cubic Inches (5.0 Liter)
Induction: Tuned Port Injection
Rear Axle Ratio: 3.42:1
Transmission: Borg Warner World Class T-5 Manual
G92 Performance Package
N10 Dual Catalytic Converters
Z28 Performance Package
Engine Modifications:
K&N Conical Throttle Body Clamp-on Air Filter
160 Degree Thermostat
Secondary Fan Switch By-Pass
MSD Cap, Coil, 8.5mm Wires, Rotor, and 6A Ignition
Accel HEI Module
JET Adjustable Fuel Pressure Regulator
JET Fan Switch
Quaker State Hi-Performance Oil
Computer Modification:
Ed Wright (Fastchip.com) Stage 2 Performance Chip
Interior Modifications:
Macewen White Gauge Face Overlays
Auto Meter Phantom Oil Pressure Gauge in A-Pillar
Hurst Comp/Plus Shifter
Kenwood CD player and 7x10's Mounted in Rear Cargo Well
Exhaust Modifications:
Gutted Catalytic Converters
3" Intermediate Pipe
Flowmaster Crossflow Muffler
3" Chrome Tail Pipes
Suspension Modifications:
Addco Sway Bar End Links (Polyurethane)
Gabriel Hi-Jacker Air Shocks (Rear)
(Will soon install a Spohn Tubular Panhard Bar)
Exterior Modifications:
5% Window Tint
GTS Taillight Blackouts
Black GTA rims
Best 1/4 Mile Dragstrip Pass To Date:
Solo:14.739 Seconds @ 94.42 MPH
With Passenger:15.009 Seonds @ 93.51 MPH
A Run of 14.5 Is Possible, But I Have to Wait for My Shifter Springs to Arrive (Mine Are Missing for Some Reason). The Run I Know Which Should Have Achieved This Was Against a Mustang Who Ran a 14.865. I Was Ahead By An Entire Car-Length the Entire Run Until My shifter Hit the Gate For Fourth Gear, Causing Me to Miss the Gear and Grab a Very Disappointing 15.810. What Makes This Story Even Worse to Tell, Is The Fact That I Believe I Had My Best Reaction Time On This Run; a .605 Second Reaction.
[This message has been edited by 90Iroc (edited October 10, 2001).]
Accel HEI Module
JET Fan Switch
5% Window Tint
Black GTA rims
Ok here is my combo....what hp do you think I will be pushingand what kind of powerband? I am new to this modding thing(I done an engine swap before tho) and really don't know how to match up cams and such.
1) Port and polish my old LB9 heads with a valve job, new springs(what do you recommend) to replace the TBI head on the car now.
2) Heddman TES headers and Y-pipe to add to my 3" cat-back
3) Port plenum, Edelbrock Hight Flo TPI base and SLP runners.
4) Comp Cams CC08-300-8 Fuel Injection Cam Stats:
Dur(.050) I 206 E 210
Lift I .450 E .480
LSA 112
RPM Range 1000-5000
What do you guys think?
Lift I .450 E .480
LSA 112
RPM Range 1000-5000
Lift I .450 E .480
LSA 112
RPM Range 1000-5000
What do you guys think? What kind of time do you think this will get me in the 1/4 miles.....remember i am just learning about modding TPI.
Lift I .450 E .480
LSA 112
RPM Range 1000-5000
Engine: LS7
Personally, I think the cam is a little weak for street/strip 305. I have and plan on installing a crane cam 2032 214/220 intake/exhaust. 1.6 roller rockers to get lift around .480/.496". home ported/polished TPI heads, I already have edelbrock headers, plan on burning my own chip eventually, and siamesing the base. You all can have you're own opinion but i think the tuned part of TPI engines is a bunch of B/S. I can't think of anything more fun than my engine breaking at 6500+ rpms. Go for a ride in a low 14 sec N/A honda, it will open your eyes. BETTER YET, drive it yourself, ever shift a car at 8000+ rpms taking it easy on the motor(you know how our cars pull from 3000-4500 in 1st, imagine that from 6000-8400 in every gear), my *** , it's fun. I love to hate them and my friend's civic that's faster than most 3rd gens. 14.3 @97 mph, no internal mods to his 1.8L engine. I hate him too.
14.62 sec @ 93.4 mph w/ 2.23 60'.
SLP cold air w/ K&N
SLP TOTL exhaust
TPIS MAF
52mm TB w/ airfoil
Random Tech 2-1/2" cats
Accel 300+ coil and MSD wires/dist cap/rotor
Hypertech streetrunner chip
Hypertech 160 deg t-stat and fan switch
TPIS adj fuel pressure regulator
March underdrive pulley
10 deg BTDC timing
Firehawk SZ50 EP
Engine/tranny internally stock, never rebuilt, 127,000 miles.
1989 Formula WS6 M5
2001 Trans Am WS6 A4
More info at website:
http://www.fbody.com/members/stevenmh
SLP cold air w/ K&N
SLP TOTL exhaust
TPIS MAF
52mm TB w/ airfoil
10 deg BTDC timing
Firehawk SZ50 EP
1989 Formula WS6 M5
Car: 87 IROC
Engine: LB9 for the moment
ok... 89 T/A 5.0 5spd best time:14.49@93 2.1 60ft... normal:14.75@92 2.19 60ft time... elevation less than 200 ft, temp 65*f, only mods: k&n filter, 180* stat, sticky tires (255 50 16 bfg drag radials. 92k on the clock, clutch just about to tell me where to go...
zroc
zroc
Sanjay
Aug 12, 2015 03:41 PM
