can someone explain VATS
Old Apr 25, 2008 | 07:21 PM
jjlabinski's Avatar
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: Torsen "3.73"
I have an 84 TA which I put an 87 TPI unit on.
Thing used to run until I started messin with chip burning now it wont start.
I have spark and fuel pressure but it wont fire it wont even sputter or pop
it does exactly nothing yet it ran fine before I messed with the chip.
I put the ABWN memcal back in and it still wont do nothin.
COULD THIS BE VATS RELATED?
How can I verify if VATS is disabled? Does VATSeven have anything to do with my set up since it is not factory?
thanks
Jeff
Old Apr 25, 2008 | 08:30 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
Re: can someone explain VATS
go back to the homepage theres a great article in tech articles, look for vats fix,later jimmy
Old Apr 25, 2008 | 08:45 PM
avro206's Avatar
Car: 89 Formula
Transmission: TH 700R4
if your the ecm is 87 (same as the TPI your using) then it's not VATS.
VATS was not in existnece in 87
Old Apr 25, 2008 | 09:30 PM
Guest
Guest
Posts: n/a
Sounds like a bad burn. You might have a 256 chip, in which case you need to stack the bin or burn from the right address. I ran into the same issue on my 86. Check the chip and see if its a 128 or 256.
Old Apr 25, 2008 | 10:02 PM
jjlabinski's Avatar
Engine: shinny 350
thanks
I stacked the bin
Does the ABWN memcal have VATS enabled from factory
thx
jeff
Old Apr 25, 2008 | 10:50 PM
Guest
Guest
Posts: n/a
Thats an 87 code, there was no VATS in the 87 code.
Old Apr 26, 2008 | 07:06 AM
jjlabinski's Avatar
Engine: shinny 350
I was hoping that was it. Guess I am no further in along in my search!
thx
jeff
Pac J
May 17, 2020 10:44 AM
RS Reaper
Oct 17, 2018 07:52 PM
Ed1LE
Sep 30, 2018 09:14 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
AmorgetRS
Sep 28, 2015 09:33 PM
