1989 305 injector help needed
Old Apr 27, 2008 | 12:33 AM
Turbo Lover's Avatar
My 305 hasn't run right since the engine was rebuilt. I checked the injector resistance today and found this:
Cyl 1 : 15.7 Ω
Cyl 2 : 15.9 Ω
Cyl 3 : 6.0 Ω
Cyl 4 : 15.7 Ω
Cyl 5 : 10 Ω
Cyl 6 : 4.7 Ω
Cyl 7 : 6.6 Ω
Cyl 8 : 15.9 Ω
So I have 4 that are bad. Do I buy just 4 or replace them all? Where can you buy injectors that are reasonably priced? I have emailed a few people on the board but haven't heard anything yet.
thx
craig
Old Apr 27, 2008 | 05:57 AM
Theking's Avatar
Car: 1989 IROC-Z
Transmission: Th700R4
Re: 1989 305 injector help needed
Replace them all $260 19lbs ford racing injectors : http://tpiparts.net/inc/sdetail/2545
Because you never know when the other 4 will give up, its better with 8 new..
I did have 3 bad and I replaced all of them..
Old Apr 27, 2008 | 11:40 AM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
Just did the same thing on my friends car. It's been running lousy off an on for years. Finally thought to check the injectors and that was the problem. I used the Ford 19lb injectors same as Theking suggested and the car runs beautiful now.
Old Apr 27, 2008 | 04:14 PM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
go to www.fuelinjectorconnection.com
get the design 3 bosch like i did 169 for the set with a 3 yr warrantee..
Old Apr 28, 2008 | 05:44 PM
Shamble's Avatar
Car: IROCZ
Engine: LB9
Axle/Gears: posi
I have Accel 19lb injectors in my 305 TPI, car runs GREAT. I've had them for over 1 1/2 years already and no problems. Just in case https://www.thirdgen.org/injectorswap has all the info you need for a swap. Goodluck
Old Apr 29, 2008 | 02:35 AM
Theking's Avatar
Car: 1989 IROC-Z
I go with the ford injectors from tpiparts.
My accel dosent seem to work like they should (its the yellow ones... the bad ones.. the new style silver/white is much better .. but Ford Racing Injectors are much better..)
Old May 1, 2008 | 10:24 AM
Thanks King and everyone else. I ordered the 19# Ford injectors from summit racing off of ebay for $214 plus shipping. Thank you.
IROCZ1989
Jan 24, 2016 03:55 PM
Jae992
Aug 27, 2015 09:07 AM
kyleb24
Aug 15, 2015 08:24 AM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
