MAF
Old Apr 27, 2008 | 08:29 PM
IROCNMIHEAD's Avatar
Car: 1985 IROC
Engine: LB9
MAF
I have an 1985 TPI 305. My question is can I run my camaro without out the MAF? I have removed it before and the Check Engine light never came on, My reason for removing the MAF is to install an K&N Cone Filter or any other suggestions for cooler air? Also thanks to all who reply.
Old Apr 27, 2008 | 09:53 PM
Vader's Avatar
Re: MAF
It will run, but not well.
Old Apr 27, 2008 | 10:15 PM
WhiteIrocZ's Avatar
Car: 87 Iroc Z
Re: MAF
If it didn't make a difference when you unhooked it you have a problem. Mine runs like hell without it.
Old Apr 27, 2008 | 10:20 PM
Car: 1985 IROC
Engine: LB9
Re: MAF
Well I was told 1500RPM is excessive but some say its average for that year??? Its an 1985 IROC... I have retarded it but it dose
not want to change RPM
Old Apr 28, 2008 | 01:34 AM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
Re: MAF
Your car will never go into closed loop and run rich as hell. Not a good idea so you can just run an air filter that sucks in hot air anyways.
Kevin
Old Apr 28, 2008 | 09:03 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Re: MAF
Do a search on TGO on "mafless" that way you do not have to reinvent the wheel.
Old Apr 30, 2008 | 12:00 PM
intmdatr3's Avatar
Car: Monte Carlo SS
Engine: 305 W/TPI
Transmission: 2004r
Axle/Gears: 3:73 Posi
Re: MAF
I run a 85 firebird engine in my 85 monte ss. When my maf is unhooked my engine runs very rough. Looks like a diesel running lots of black smoke.
Old Apr 30, 2008 | 12:26 PM
AMigs87IROCz's Avatar
Car: 1987 Iroc-z
Engine: Swapped into a 350TPI
Transmission: T-56 Six Speed
Axle/Gears: Moser 12 Bolt 3:42 Gears
Re: MAF
Well my first question would be...WHY do you want to run without the sensor?? Do you have the elusive code #36?? It is always best to have that sensor in use and operating. The mass air flow will feedback to the computer the amount of air being passed through then the ecu decides how much fuel to throw to the injectors. You will have decreased fuel eco (like it matters) but the car will noticibly run rough...the engine is drowning in fuel.
I got so sick of the MAF...over the winter I did the MAP sensor conversion....and damn glad I did!!
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
racereese
Oct 3, 2015 03:46 PM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
