AFPR Adjustment/reading? (Guido?)
Old Oct 14, 2001 | 04:53 PM
Reno's Avatar
I took off the vacuum hose and plugged it (as per the instructions in the FAQ), and the gauge pops up to 60 PSI?!? Isn't that a little high? Also, when I set it, should it be like this (hose pulled and plugged, engine running)? If it's 60 psi now, doesn't that mean it's running nearly 18 psi higher then stock (42, I believe)? So when I do set it, I'll crank it down so it reads 42 psi, even in this maximum PSI setting?
I know, a lot of questions, but I was a little freaked when it jumped to 60 PSI at idle when I pulled the hose. Though this could explain hard starting and the rich exhaust though...
Any suggestions or instructions on whether or not I"m doing this correctly would eb great.
Guido, how did you adjust that thing without taking the plenum off? Also, what size was it again?
-Reno
89 Formula 350
"This is how you remind me of what I really am..." - Nickelback
Old Oct 14, 2001 | 10:16 PM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
I have the Holley unit that has the flat top to adj with your fingers. I took off the vaccum hose and plugged it with my fingers then losened the cap until I read 36 psi (because that is the best for me to be running according to scan tool) Easy as that you are headed in the right direction. Also yea that is probably the problem you are running rich if you started the car with the FP that high.
Old Oct 14, 2001 | 10:34 PM
breathment's Avatar
i think, stock is 46 but +- 2 is ok
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
http://www.geocities.com/david_angel_16
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
2012sergen11
Oct 13, 2015 07:38 PM
Reid Fleming
Oct 10, 2015 09:56 PM
alpine247
Sep 16, 2015 05:25 PM
355tpipickup
Sep 4, 2015 05:32 PM
