160* vs stock thermostat
Old Oct 8, 2001 | 11:17 PM
mtccl's Avatar
I'm thinking of switching to a 160* thermostat. Don't have overheating problems, just wanted to know any thoughts. 305 TPI with stock chip, light mods.
1987 Trans Am, 305 TPI, K&N, Cherry Bomb Muffler
"35 yr old helo pilot
with a cool new toy my 17 yr old son wants"
The Phoenix Project..click to see my project car
Old Oct 9, 2001 | 01:43 AM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
You'll only notice it on the highway b/c the stock chip doesn't turn the fans on until 220*, a cooler stat is required for many aftermarket chips. I never noticed any problems with not going into closed loop or anything like that. I ran a 160 stat with my stock chip for about a year w/o any problems or gains/losses.
Old Oct 14, 2001 | 06:23 PM
89formula422's Avatar
a 160 thermostat wont let your transmission get to temp and will cause early failure, atleast dats what my dad says and he owns his own tansmission shop. Just trying to help
Old Oct 15, 2001 | 10:03 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
Too bad he's wrong. The tranny will have no problems getting up to operating temperature, and the lower-temp 'stat actually better for it since it has a better chance of keeping it from heating up the tranny fluid too much (which is a cause of tranny failure). The torque converter clutch won't engage until the coolant is around 122 (or is it 132?) degrees F, so that's not a problem either.
Greg Westphal
'87 IROC 355TPI/A4
Old Oct 15, 2001 | 01:07 PM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
There are many functions in the computer that will only work at temperatures higher than 160, and in cold weather you run the risk of staying in open loop mode. A 160 stat is really colder than you want to make power. The hotter the coolant, the less heat loss from combustion and more power. The tradeoff comes in when you encounter detonation. There is a balance between coolant temperature and ignition timing. 180 degrees seems to be the best for coolant temp, and then set the timing from there.
89 Transam GTA, 350TPI, auto, 3.27 rear, dual cats, gray.
Magnaflow cat-back,
K&N open element,
Best E.T. 14.63@95mph
Old Oct 16, 2001 | 04:57 AM
Kandied91z's Avatar
well i run a 160 and it works fine although i store it during winter so....... i would probably go with a 180 if it was a winter vehicle as well.
italiano67
Dec 11, 2016 09:21 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Genopsyde
Oct 7, 2015 08:35 PM
Wade787b
Sep 29, 2015 01:15 PM
perZ
Aug 15, 2015 01:17 PM
