How much hp are K&N's worth on a stock 305TPI???
Old Oct 15, 2001 | 10:54 PM
IROCME's Avatar
Car: 1986 IROCZ
Engine: LB9....rebuilding coming soon
Transmission: rebuilt 700R4
Just curious cause I might get a set.
86 IROCZ 5.0 TPI/"new" 700R4 auto with transgo shift kit and vette servo,canary yellow,t-tops,radar detector,tan interior,hidden antenna,tinted windows,taillight blackouts,front end bra,k&n air filters,no cat,full 3" racing exhaust with 40 series flowmaster and chrome tips,2:73 posi rear(soon to be 3:42 or 3:73 posi),1989 IROCZ 16*8 polished aluminum rims
Old Oct 16, 2001 | 12:17 AM
vortech305's Avatar
depends on what type of K&N the cone or the regular factory type, proabably 2 rear wheel
Old Oct 16, 2001 | 04:54 AM
Kandied91z's Avatar
don't get your hopes up.......... they help in the greater scheme of things. but if you don't have them you should.
Old Oct 16, 2001 | 07:03 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
I wouldn't expect any gain whatsoever really. The advantage is you can clean them regularly (say every other oil change) and be sure that your filter is never dirty, which would cost you performance. It's good preventative maintenance all around.
Ed Maher - Moderator @ The TPI & Carb Boards
92 Z28 Convertible - Quasar blue / Tan top
305 TPI A4 2.73 - 14.74 @ 93.25
Stock except ported plenum and dual cats
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
Old Oct 16, 2001 | 09:28 AM
palric's Avatar
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
I guess I have to go against the grain. I have a '91 Formula LB9 TPI G92 setup for 230hp and 300lbs torque. I have about 40k miles on the car and engine.
I bought a K&N cone, oiled it up and attached it directly to the throttle body as per instructions while disconnecting the factory intake gear.
My first run was a noticeable improvement. The next few runs got better and by the second day I can say that there was a definite and clearly noticeable improvement in power. I measured this in rpms which now made power to between 5750 and 5800 -- it pretty much died off at 5500 before. More important, the seat of the pants was most improvement was most noticeable at around 2800rpm where there was a real improvement in torque.
Don't get me wrong, I am not trying to say you will start taking C5 Corvettes with a silly filter upgrade. But it was clearly a noticeable improvement and therefore I consider it a good investment for bang-for-the-buck.
Now keep in mind I have a Firebird induction setup which may be more restrictive than the Camaro setup ? So I might see a bigger improvement just because my factory setup was more restrictive.
BTW: I took the cone off because IMHO it made too much noise. I ended up buying a factory replacement Holley Power-Shot filter, cut open my factory filter canister and saw a noticeable improvment with this mod as well.
RP.
'91 Formula Firebird G92,WS6,5-speed,3.42 a ton of fun to drive.
1992rs/ss
Jan 31, 2025 05:10 PM
Street Lethal
Apr 30, 2019 12:14 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Navy8125
Aug 21, 2015 09:32 AM
jbd1969
Aug 17, 2015 07:06 PM
