code 33 when car is cold
Old Oct 15, 2001 | 05:42 PM
MARKT111's Avatar
Car: 1989 TTA
Engine: 3.8 Turbo
Transmission: 200R4
I know this is the code for the MAF gm/sec hi,what does that really mean and how do I fix it? is it a tuning issue? it just started rescently and does it maybe twice a week with no other codes
89 FORMULA 350,WS6 SUSPENSION,HOTCHKIS STB,KONI REDS,WONDERBAR,SLP REAR CONTROL ARMS/PANHARD,POLY BUSHINGS,FRESH 355 MOTOR,TCI 12" STREETFIGHTER,TRANSGO SHIFT KIT,3.70 GEARS,FLOWMASTER EXHAUAST,SLP 1 3/4 HEADERS,NO CATS,58 MM BBK,MINIRAM INTAKE,COLD AIR,ALL FREE MODS
Old Oct 15, 2001 | 06:16 PM
Guest
Guest
Posts: n/a
Check your TPS setting, if its too high it will set that when cold.
Old Oct 15, 2001 | 07:15 PM
MARKT111's Avatar
Car: 1989 TTA
Engine: 3.8 Turbo
Transmission: 200R4
I just reset the TPS in a complete tune up 2 weeks ago(it was .63 now it's .45)trying to get everything tuned in perfect before engine work.I don't want to have problems when cam and heads are in that were prior issues
Old Oct 16, 2001 | 08:02 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
Check and/or replace your MAF sensor relays. One is for MAF Power and the other is for burn-off, but I don't remember which one is which. For as cheap as they are, it's good insurance to replace both at the same time and not have to worry about them again.
Greg Westphal
'87 IROC 355TPI/A4
Old Oct 16, 2001 | 10:37 AM
elec87's Avatar
Car: ls1 rx7, 2 99 hugger orange ss cars
Engine: ls1's
Transmission: 6 speed, autos
Ok i have the same problems, Except that I have replaced the maf burn off relay. But now everyonce in a while i get a 33 and 36 and it is usually a hard code right from the start up. what could cause this?
Old Oct 16, 2001 | 10:41 AM
Guest
Guest
Posts: n/a
I've traced down the 36 before to a weak battery. Any wiring problems like a short, crossed wires, etc. will cause problems as well. On my car at one time or another the wires got eaten by the radiator fan and that of course threw me a code.
Old Oct 16, 2001 | 02:43 PM
prepz28's Avatar
Believe it or not it could be your air filters. i got the paper ones wet once and i had a code 33 for a month before i discovered my filters were all crunchy. also replace the relays. expect to pay 8-13$ a piece. replace the FP relay while you're back there, all three are the same.
Wade787b
Sep 29, 2015 01:15 PM
apie2546
Aug 10, 2015 05:43 PM
drathaar907
Aug 6, 2015 04:20 PM
