will batch fire cause weird fuel pressure readings?
Old Oct 16, 2001 | 04:42 PM
breathment's Avatar
Should the fuel pressure be perfectly steady when idling, not changine RPM's, or would the way the injectors fire cause the pressure to flucuate a little?
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
http://www.geocities.com/david_angel_16
Old Oct 16, 2001 | 06:40 PM
Reno's Avatar
Mine fluctuates, +/- 2 lbs or so at idle. Don't know if that's regular, but it runs fine like that, so I think it's just part of the batch fire system.
-Reno
89 Formula 350
"This is how you remind me of what I really am..." - Nickelback
Old Oct 16, 2001 | 06:48 PM
JETHROIROC's Avatar
Breath, mine's perfectly steady at idle and increases at WOT, but still steady.
Maybe the fuel pump isn't providing enough flow to keep up?
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, MSD coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Accel 23# injectors, Holley module, ported plenum,
Ported Daytona Yellow stock base, Moroso valve covers, other stuff,
Streetdampr, Ruger P95DC, hot wife, new oil filter, !cats, !TBC, !AIR.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
Old Oct 16, 2001 | 07:47 PM
MARKT111's Avatar
Car: 1989 TTA
Engine: 3.8 Turbo
Transmission: 200R4
I have the same thing,it bounces +/-4 lb's very quickly,
Old Oct 16, 2001 | 08:06 PM
breathment's Avatar
well i went out, and i was gonna unplug each injector to see if one was screwing up, well hooked up the guage, and it was steady .. and a couple weeks ago it was jumping around, so i have no clue what was or is wrong.
- David
Old Oct 16, 2001 | 11:40 PM
airdeano's Avatar
possible weak injector windings..
meaning an injector may open, but can not
remain open do to the weakness in the windings.
i just pitched one that was doing the same.
plus one not even opening. clicked and pressure
was there, just wouldnt spray.
replaced the injectors and problems went
away...
airdeano
92camaroJoe
Jul 29, 2023 07:57 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
mdtoren
Aug 16, 2015 05:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
