Unhooked Vacuum Lines (Pics)
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Can someone show me what plugs into these? The second one is hard to see, but it is a small plastic piece that comes from the bottom of the throttle body.
http://s214.photobucket.com/albums/c...t=DSC03113.jpg
http://s214.photobucket.com/albums/c...t=DSC03111.jpg
Car: '86 Iroc Z
Re: Unhooked Vacuum Lines (Pics)
I replied in one of your earlier posts about your car stalling and mentioned that you are going through a lot of what I just got over. Go to a trusted shop and have them rewire your vacuum system, it's not that spendy (I paid a few hundred) and they make sure everything is correct and use new materials. After my rebuild, I learned how touchy the vacuums are on these cars and it's very important that the vacuum is 100% correct before you try and diagnose any other problems.
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
Bottom of the throttle body should go to a T, which one line goes to the charcoal canister, the other under the plenum and to the EGR solenoid ( your first pic ) the other line from the EGR Solenoid goes to the EGR.
Car: 1989 IROC-Z
Transmission: Th700R4
First pic is EGR Solenoid, one line to the front of the plenum (under on driver side) and the other connection goes to the egr on the middle of the intake..
The second pic is the heater valve, thats vacuum hose goes into the firewall.. For closing and opening for the hotwater to the heater/AC..
Car: '83 z/28
Axle/Gears: Stock?
I am trying to figure this out also, looking at the egr solenoid, if you look on the right hand side of it, you see a little metal clip on the solenoid. what plugs into that?
mdtoren
Aug 16, 2015 05:45 PM
