Who can machine my plenum?
Old Oct 15, 2001 | 11:56 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Are there any good places in the Woodbridge/Manasas area that could match my ports to a 58mm TB. About how much would it cost? Thanks.
Old Oct 15, 2001 | 03:49 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
You're insane if you pay someone to enlarge the throttle bores. You could open them up with a dremel in less time than it would take to get in your car and drop it off at the shop.
Ed Maher - Moderator @ The TPI & Carb Boards
92 Z28 Convertible - Quasar blue / Tan top
305 TPI A4 2.73 - 14.74 @ 93.25
Stock except ported plenum and dual cats
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
Old Oct 15, 2001 | 04:49 PM
cobrakiller1989's Avatar
I agree, and if you dont have a dremmel, get one. they are very handy
*1989 RS
*Red, Daytona Turbo fiberglass hood, chrome 16x8 IROC wheels
*355 CID
*TPI ported plenum, SLP siamesed runners, Edelbrock high flow intake
*Edelbrock TES Headers (getting SLP 1 3/4)
*Richmond 3.73, Auburn Posi
*Modded 700-R4, 2800 stall converter
Old Oct 16, 2001 | 11:45 AM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
I got a dremmel. What tip do you use and how do you get the aluminum to stop sticking to the bit?
Old Oct 16, 2001 | 11:04 PM
91'firebrd's Avatar
If your Dremel is anything like the battery powered one I have it would probably take about 6 hours just to get rid of the casting bump right behind the throttle body.
What you need is a die grinder that plugs into an outlet. I tried all kinds of different bits and I know from experience that all the "stone" type bits are pretty much worthless on alum. Get a bit made for alum. Best one I have is cone shaped and has spiral edges around it. A neighbor that works with aluminum tanks gave it to me.
Old Oct 16, 2001 | 11:28 PM
86TransAmTPI's Avatar
well when i ported my plenum i also used the bits like 91firebird is talking about...I have to agree they are the best.I went to sears and bought a couple different sizes,like a big and small cone shaped and a big and small cylinder shaped.I noticed the bits began to clog up with aluminum from the plenum fairly fast,so i took whatever i could find like a screw or nail,and i used the pointy end of it to pull out the aluminum stuck in the bit,and the aluminum comes right out of the bit too and the bits remained virtually undamaged.But heres a lil trick i used also,to help stop the bit from clogging.I had a little spray bottle filled with water and as i drilled i constantly was soaking and spraying the bit,and since it wasnt getting too hot the bit didnt clog up nearly as much as before i used the water trick.
86 Trans Am 305 TPI,Bored 30 over,Blower Cam,Fordged Racing Pistons,High Volume Oil Pump,3" Flowmaster Exhaust,Hypetech Coil,Acell 300+ Race Wires,Bosch Platinum +4 Plugs.Best Et was 12.5 with a Paxton.
Old Oct 17, 2001 | 12:01 AM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
If you choose not to do it yourself, http://www.lingenfelter.com sells them. They are VERY expensive though. You also need to provide your plenum as a core. I believe http://www.cruzinperformance.com does custom porting too. Those of you who used a Dremel have far more patience than me. Using an air powered die grinder it took me about 4 hours to get the TB openings enlarged.
92Z28
89GTA
Old Oct 17, 2001 | 12:48 AM
airdeano's Avatar
a good lube is 80-90 gear oil. keep it wet
and the clogs dont happen as much. speed of
the tool prevents the chips to fly off and
clogs the bit. plus the bit can only do so
much and we lean on the tool to go faster
and CLOG. the only drawback is the smell..
burning gear oil isnt to sweet. but it does
keep the bit temperature down.
hope this helps
airdeano
Old Oct 17, 2001 | 11:35 AM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
Thanks a lot fellas. I'm going to start no it today.
bigjay89gta
Oct 15, 2015 08:04 AM
toronto formula
19
Oct 6, 2015 12:27 PM
