bad hesitation and rough starting.....
Old May 23, 2001 | 09:48 PM
TransAm182's Avatar
alright guys you gotta help me with this one...its been screwin with me for weeks...ok i got a 85 trans am tpi with auto tranny...heres the deal...its got new plugs, wires, cap, rotor, fuel pump, air filter, throttle body has been cleaned, the timing is fine, the wires arent crossed or arching...when i go to start it cold it takes a while to catch and starts real rough...it will idle at about 2000 and gradually come down until it stalls...to keep it from stalling i have to keep hitting the throttle...this is the thing though...when it reaches operating temperature it idles fine and will start right up...also on the road its terrible when i put the slightest load on it, it will hesitate like crazy and gurggle and gargle...its driving me nuts (no pun intended) PLEASE HELP ME!!
Old May 24, 2001 | 03:50 PM
Ryan Theroff's Avatar
My girlfriends '85 Z28 does the same thing I haven't been able to fix it either. You hop on it and it bogs down and wants to die then jumps. I'd like to get an answer on this too. Sorry I cant help with the question but I beileve it must be a common problem on all the early TPIs.
Ryan
Old May 24, 2001 | 05:56 PM
87iroczmd's Avatar
pull the trouble codes, it will be easier for people to help you, if you don't know how check the tech articles, or the faq
Old May 25, 2001 | 02:18 AM
kane91z's Avatar
Car: 91 Z28
Engine: 5.7
mines been the same way - but it never throws a code so im thinking its either a clogged/chacked injector, my o2 sensor is bad, or maybe my egr...
91 z28 lb9 5 speed - hooker 1 5/8 headers - high flow cat- full 3 inch exhaust - home made ram air - tpis airfoil - dual chamber flowmaster - Stage 2 Jet Chip and 160 stat - 8 mm Msd plug wires - 55,000 v hypertech coil/rotor/distrib. cap - Mac. White face gauges - lots of sound system crap...
Old Oct 17, 2001 | 10:31 PM
Ziimo's Avatar
this sound exactly like what my motor does. someones gotta have some answers or ideas on what might cause this problem.
Old Oct 17, 2001 | 10:35 PM
TransAm182's Avatar
it was the fuel pump....
TrevinE
Sep 14, 2015 03:20 PM
webeeZ28
Sep 14, 2015 12:00 PM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
Blue419
Sep 10, 2015 01:03 PM
Accerrito22
Sep 5, 2015 09:34 PM
