what injector are these???
Old Apr 30, 2008 | 05:41 PM
gkrynick22's Avatar
Car: 1985 Corvette/Searching For F-body
Engine: 350 TPI/????
Transmission: 4+3 Manual/????
Axle/Gears: 3.23/????
Hey I am trying to identify injectors pulled out of a mystery motor. I have searched threads and found nothing, so hopefully someone can help. Any help would be great!
Attached Thumbnails what injector are these???-dscn09342.jpg   what injector are these???-dscn09332.jpg
Old Apr 30, 2008 | 10:18 PM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
Re: what injector are these???
Heres what I came up with:
Bosch- 0280 150 222 Application: '85-'86 CHEV 5.0L V8(BLACK)(STYLE II)(IC-010)(5235047)
I have chart that I use to identify these. This part number has limited info but it appears to be an earlier Bosch Chevy injector. Since the application is listed as 5.0L chevy I would assume it is an 19lb injector.
Here's a link to the chart I use
http://www.members.lycos.co.uk/maxbo...plications.pdf
Hope that helps
Old Apr 30, 2008 | 10:54 PM
burnout88's Avatar
Car: 88 IROC
This site here also lists it as a 5.0 Chevy application
http://www.injectors4u.com/multiport_injectors.htm
These two links also provide additional info: Impedence: 16 ohms, 194cc/min
http://www.witchhunter.com/injectordata1.php4
http://www.witchhunter.com/flowdatapix/b0280150222.jpg
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
