LT1 or vortec head/intake??
Old Oct 15, 2001 | 12:34 PM
WHITE87GTA's Avatar
i was planning on going with the vortec head/manifold combo with LTR and ported plenhium with a LT1 hot cam but now i am thinking about doing the LT1 manifold swap. any comments on what would be better.
I plan on using the LT1 hot cam or something very comparable and i am also aware that if i use the LT1 maniflod the stock heads will be changed out with something else other than using vortec due to there different port size.
Old Oct 15, 2001 | 08:59 PM
ImportsRsloths's Avatar
I just got a 93 lt1 with the fuel rail and injetors..... thats the easy part i think the computer with MAF will be a BIATCCHHH>>.
Old Oct 15, 2001 | 11:29 PM
airdeano's Avatar
white87gta,
the hot lt4 cam will be a good choice. short
runner design will encourage upper end power.
low end will lag until 2000rpm. gears can fix
that. the votec swap to lt1 intake will be a
lil more difficult than the standard head.
because of the vertical bolt placement. or drill
the heads for the pattern. but im thinking the
high roof will still be a problem as it is for
stande manifolds. the lt4 has a higher roof
and id think it a better swap to vortec/fast
burn head. im doing a long tube runner/vortec
motor, then to a ramjet manifold, then to a
lt4/miniram then a tunnel ram with 2 vortec
throttle bodies. to see the different characteristics
of each. with the hotcam.
importsrsloths,
the computer would be easy with the MAF. just
treat it like a minram style intake. a lil
more gear and fatten up the upper rpm. a bigger
throttle body would be better 52mm.
airdeano
Old Oct 16, 2001 | 10:01 PM
WHITE87GTA's Avatar
thanks for the reply but i think you might have misunderstood me.
i know that if i go with the LT1 manifold/intake (properly machined to fit) i will have to use standard type heads (non-vortec) that will compliment the cam when properly preped.
or i will use the vortec heads with the new manifold that is available to be used with the vortec heads with a LTR setup.
the question is which set up would be better? i figure the engine will be required to rev to 5600-5800 rpms which will be at the extreme top end capabilities of a LTR set up.
Old Oct 17, 2001 | 02:01 PM
Consider that A LOT of LT1 guys have run 9's with the stock intake (power adders help though )
Old Oct 17, 2001 | 11:07 PM
airdeano's Avatar
vortec heads in stock to mild prep will not suffice
the higher rpm. with 170cc intake port a good
mid range pull (2200-4800) is where they shine.
better head to concider is the fast burn. when
you get the vortecs prepped youd have 3/4 the
price of fast burns. and would lose out on
the thermo-effiency. i saw where some one did
a cfm comparison on several heads and the vortec
faired 8th outta ten.
"i was planning on going with the vortec head/manifold combo with LTR and ported plenhium with a LT1 hot cam but now i am thinking about doing the LT1 manifold swap.
unless the use of better heads the LTR will suffer.
airdeano
Old Oct 18, 2001 | 04:51 PM
WHITE87GTA's Avatar
looks like it will be the LT1 manifold for me.. now the question is what type of head to use. i was thinking either the dart iron eagles fully preped (ya i know they are not alluminum) or the afr 190. looking at cost the darts seem pretty reasonable in cost and preped will flow very well. just wondering outloud if i will regret not going with the afr 190's. any opinions?
88SS6SPEED
Nov 11, 2015 07:05 AM
Quzyle
Oct 15, 2015 03:35 PM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
monte87cortez
Sep 26, 2015 08:10 PM
