Compression Ratio?
Old Oct 9, 2001 | 12:49 PM
88 IROC BOB's Avatar
Compression Ratio?
Well, Im throwing around the idea of a head and cam swap. With the stock CR being 9.5:1 what would happen to the CR with either the Edelbrock 6085 with 60cc chamber or the TFS 23* with 64 cc.
I thought I had heard that when going over to aluminum you should definately raise it up by .5-1.0 point.
I don't know what the size of the chamber is on the stock iron heads.
Oh, and the cam I'm thinking of is the CC XR269HR.
Bob
350 TPI, 700R4(rebuilt), K&N's, MSD 6AL, Headers, Flowmaster, 160* stat, airfoil, MAF screens cut out. 13.88 @ 101.18 mph
Old Oct 9, 2001 | 01:20 PM
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
When going with aluminum, you often run a much thicker head gasket. So take that into account when calculating your final compression.
I run 9.75:1 compression. (Edelbrock 6089) No problems.
Mark.
Old Oct 11, 2001 | 11:24 PM
Guest
Guest
Posts: n/a
The stock cc is 64 on a 350, so with the trick flows it would be the same if you used the same thin factory gasket, but I wouldnt do that... probably be around 9.1, with the 60cc chamber it would be 9.9 with a thin gasket or 9.5 with a normal gasket.
Cam looks good, the TFS would probably work better if you want my .02
Old Oct 18, 2001 | 04:43 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Stay on the conservative side of compression. The little bit of power you gain by going high on compression will be lost and then some if you have detontation problems with 93 octane. Unless you plan on running so type of booster at each fill up.
IM using the trickflows on my 406 with flat-top pistons and having to cut the timing alot in the chip to stay out of detonation.
90 IROC
SuperRamed 406
Trickflow 23* heads
Old Oct 19, 2001 | 06:54 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
I second what MikeH said. When the engine builder and I were looking at pistons for my 355, we chose a certain SpeedPro piston with a slight dome that would've given me 10.4 compression with the 66cc combustion chambers (TF 23* heads with the CNC-ported chambers) and standard deck height. Well, the block had to be decked to zero (not that I minded, since it gives a smaller quench area for better combustion), which gave me 11.1 compression. I can't run over 26 degrees of total timing at WOT due to detonation, although I think I can get more by richening it up some. If I would've calculated the CR before the final assembly, I would've ordered different (flat-top) pistons.
Greg Westphal
'87 IROC 355TPI/A4
InfernalVortex
Apr 20, 2021 11:31 AM
FormulasOnly
Jul 23, 2018 08:47 AM
Vincent135
Sep 28, 2015 10:50 PM
Damon
Sep 26, 2015 04:29 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
