What is the Fuel Line "thread size" ?
Car: 86 IROC Convt
Engine: 305TPI
Transmission: TH700R4
Ya' know - the hoses that go from the inner fender and over to the TPI, what is the thread size? I want to replace them with braided hoses, and all I can find are the AN type fittings, so I will need some type of adaptor. Does anyone have any info on whats needed???
Thanks for any help!
Ken
1986 IROC-Z Conv't
- White Gauges, 17x9.5 TT II rims w/275/40x17" F1s, 1.5" Jamex Lowering Springs, BMR stb, Lakewood APR, PST suspension parts, Edelbrock Trailing Arms, KYBs, Edelbrock RPM Cat-Back, Edelbrock JHC Headers, Catco, World Products Heads, CompCam, SLP runners, Ported Plenum, K&N, Airfoil +polished/billet dress-up stuff
ChevyKen's Cars
Administrator @ ChevyWorld.net
Ken
1986 IROC-Z Conv't
ChevyKen's Cars
supply is 16X1.5
return is 14X1.5
Accel makes fittings to go from these to AN
Weatherhead and earls make fittings to go from this to 3/8 iverted flare. I have only seen male adapters so I realize this may not help. Your best option may be to pull the lines and cut and flare them to what you want.
John
Heart of Texas Power and Performance
return is 14X1.5
John
I got my kit from Lingenfelter...its made by accel...it allows you to use a AN fitting/braided hoses and connect to a 3/8 saginaw stock line.It should also come with a adaptor to a 7/16 size as well.Thats a common return line size.
The size was a -6N adaptor/hose size.
It allows you to connect to a TPI fuel filter or connect to the fuel rails.
Word of caution...I redid my fuel lines in braided hoseson my 86 Vette made by aeroquip...while no problems whatsover,they vent gas fumes.Its not very strong but routed by exhaust or engine heat,who knows what coud happen.
I can smell gas if i get my nose close to the lines anywhere...try and find or ask the manufacturers about lines that wont vent fumes..Ive heard now you can get them teflon coated or something inside.
Just wanted to pass this along.
1986 Vette Coupe,auto, 357 L98 w/alum. heads,40 over,crane cam,3.73 Gears,The usual Mods..
Had an 86 Bird before..want to get another F car again!
theshackle
Mar 5, 2017 06:37 PM
ambainb
Apr 25, 2016 09:21 PM
AkDrifted
Aug 17, 2015 07:45 PM
