Vortec heads / new TPI base-- Anyone have documented power results in yet??
Old Oct 20, 2001 | 09:05 PM
esams's Avatar
I'm fired up about buying Vortec heads and the Scoggin Dickey base right away, but I won't take their word for it about the power claims. They state 300 flywheel hp on a totally stock runner/plenum/throttle body/computer setup, and 375 hp with cam, injectors, and roller rockers. Any guinea pigs yet? Let's figure out what cam setups will max this combo out!
'99 Corvette Coupe, auto, Yank 3500 Converter, custom cold air, no cats, hypertech, TBB, ported MAF, 3.42 gears, dry nos setup.
Best times at 4200 ft. Elevation, 1.90 60 ft./12.61 @ 112.68 Mph
Dyno NA 311 RWHP / 348 torque
Dyno 85 shot nos 395RWHP / 434 torque
'91 Z28 350 TPI auto, 3.23, TPIS fastpak, pulleys, ported plenum and base, flowmaster muffler. Brand new to me 10/20/01, no track times, no dynos, no clue, but modding fast!
[This message has been edited by esams (edited October 20, 2001).]
Old Oct 21, 2001 | 01:02 PM
Earl 87gta's Avatar
Not yet but we have a grup purchase going on write now for this tomarrow some time Im supose to get a price from SDPC so you may want to get on it with us they told us 350 with 10 orders we have 15 so im hopine we can get it for around 300 e-mail me if your interested.
Old Oct 21, 2001 | 06:53 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
y would you buy the vortec base when now they have vortec heads drilled out to be used on the old intakes?
Old Oct 21, 2001 | 06:59 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
<font face="Verdana, Arial" size="2">Originally posted by Mkos1980:
y would you buy the vortec base when now they have vortec heads drilled out to be used on the old intakes?</font>
they do?????? please explain when where and how much???
Check out MyGTA Nicknamed:The Big Red Machine
***AOL IM ClarkeMustGoNow***
Moderator at www.transamgta.com
"What does not kill us only makes us stronger"
Tony
Old Oct 21, 2001 | 07:57 PM
Earl 87gta's Avatar
If you take and put the stock base on an engine with vortec heads and look at the edge of the intake you will still see the ports of the vortec heads they are abought an 1/8 longer then the base will even cover so the heads being drilled for the bolt patern is not the big probem if you use a raceing high $$$$ intake for carbs you usaly do not have this problem the reason being that they are desined for heads that have had major porting and have a thicker seal area around the top of the port so their is plenty to shave off to make them match the heads.but with the stock or even an aftermarket tpi base you do not have this option the after market base will cover the ports but their is not enough meat around the top of the port to port match it to the heads so if you used this base even ported out as thin as you felt safe you would still reduce the size of the port going in to the head and this would restriced the flow of air.when I modify a stock or after market base to work with vortec heads I have to add 1/2 in around the top of the ports on a stock intake I will port past the origanal outer edge to match up the ports.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
