SLP Runners
Old Oct 18, 2001 | 06:47 PM
Fred91TA's Avatar
Car: 1991 Trans Am
Transmission: 4L60
SLP Runners
Well, I don't really like the look of these things, but lack of funds dictates my direction. Are the SLP runners in any way comparable (performance-wise) to the AS&M, Accel, or the TPIS? If not, are they worth my money? I'd be attaching them to an Edelbrock base. With the SLP headers I'm about to buy what kind of gains could I look for in addition to the runners, base, and my signature? Thanks
91 TA 5.7 TPI Automatic.
w/WS6 and 3.23 rear.
K&N Air Filter,Hypertech Coil,Moroso Blue Max Wires, Bosch Platinum plugs gapped at .050,
JET fan switch,JET air foil,Dual cats with Flowmaster 3" exhaust (Headers coming soon),GM Performance PROM, Complete PST components on front suspension, Spohn LCAs/Panhard bar.
My car only uses Mobil 1 transmission fluid, oil, and differential fluid.
Old Oct 18, 2001 | 09:28 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
I have the SLP runners on my Edelbrock intake. I have no proof they are better than stock but just looking at them they have to flow more air than stock runners. I also cleaned them up and matched them to the intake. I picked mine up used/cheap.
I noticed a gain when I added them to my stock L98 5.7 TPI motor (redundant) so I imagine they also help my ZZ4TPI breathe better.
Rob P
89RSconvtZZ4TPI Edelbrock Intake
SLP Dual Cold Air Intake 1 5/8" Headers Semi-Siamesed Runners, IROC
suspension, alum shaft. Numerous mods.
92Z28convt5spd (stock)
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Oct 18, 2001 | 10:55 PM
BklimNova's Avatar
I had a stock ported base plate modified to fit Vortec heads With a healthy cam(224 deg dur.@.050 .525 lift 1.6 rockers), when I put those SLP runners on my car, granted I have a lager air demand than you, I went 4 tenths faster! So in my opinion there great.
BklimNova
Old Oct 19, 2001 | 12:18 AM
moldman's Avatar
Car: 89 Formula
Engine: 305 tpi
Transmission: 5-speed
Axle/Gears: 3.45 Borg-Warner
I put the SLP runners on 5 years ago,and I felt a noticeable difference. They have a long flat torque curve that makes good power from 2500rpm to 4800rpm.
Old Oct 19, 2001 | 08:11 AM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
A freind of mine was contemplating buying these runners, and some people actually said their cars got slower ... a 14.0 to a 14.2. Now it was a while ago, and I have no idea who these individuals were, but I personally don't trust the siamesed long tube version. There is a tech article somewhere on this board where whoever it is said that he was glad to trade that nagging low end torque for high end HP, and that just turned me off to the whole idea. Admittedly, recently everyone seems to be having good results with them. If there is anyone who also dislikes siamesed runners, let me know and I guess we can form a club or something.
If I were you, though, I'd put the money in the bank, and either buy the AS&M's or Accel's, maybe a SuperRam. I figure I'll either spend the money twice now, (once if I buy them, once when I buy As&M's), or I'll spend it once a little bit later.
Old Oct 19, 2001 | 02:28 PM
BadSS's Avatar
Judging by the picture in the Summit catalog and from what I’ve gathered on this board,, the original or old SLP design had an fully open or siamesed runner for #5 and #7,,, and for #2 and #4 runners. I think they attempted to produce “dual” torque peaks,, or at least make a wider and flatter torque band with them. Myself,, I don’t particularly care for that design principle,, and I’ve got a feeling most of the negative feedback on the SLP runners are from folks with the old design. The newer design SLP runners - as cast, are “siamesed” around 1.5” for each runner, making them only about 1.5” shorter than a stock runner. I’ve modified a set of the new design for our IROC and I like them. I would not have bought a set of the older design.
Old Oct 20, 2001 | 01:42 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
i had the slp's on my car and they were acceptable for the price.i would recommend taking a sawzall to them and cutting out the divider of each runner.with an 8in. blade it's no problem.by doing that you effectively shorten the individual runner length giving you higher rpm capabilities.as far as the design;for modifying they're perfect.start at the top of the runner cut down,turn the runner over cut down,turn the runner 180* and continue,the divder will come out in a large piece a little cleanup once the main portion is out of the way will be neccesary.
87 trans am,gm crate 350(4 bolt mains 10to1),L98 aluminum heads,LT4 hot cam,slp runners,slp 1 5/8 headers,3in.y-pipe,edelbrock base,hi flo cat,air foil,afpr,as&m ported plenum,gutted airbox,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ed wright's fastchip,relocated iat sensor,160 fan switch&t-stat,tb bypass,accel supercoil,cap& rotor,slp 3in. catbcak,a/c delete.
SHE IS GONE BUT I KNOW THE GUY WILL GIVE HER A GOOD HOME.
best e/t:
3653lbs./full tank+ driver.
14.10@96.53mph 2.01 60'
[This message has been edited by PETE (edited October 20, 2001).]
Old Oct 20, 2001 | 10:07 PM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
I think the people who may have problems with SLP runners are the ones who have poorly matched setups. I have until now heard nothing but positive things about SLP runners...they are probably the closest thing you'll get to a Super-ram for a fraction of the price...but you do get what you pay for. Another mod that helps the pocketbook when you have knowledge of porting and customizing parts!
Old Oct 21, 2001 | 08:13 PM
Earl 87gta's Avatar
I have SLP runners and I think they perform well all thou it did take some getting use to the way they look if you polish them up they look a lot better I think the biggest problem people originally had was that they wear not porting the plenum to match them so the results were not as good but if you get a set of large mouth gaskets and port mach the plenum they do really well plus it shortens the runner size like 1 ½ Don or Dan cant remember last name but he use to have a web site that showed this if you do a search on slp runners or porting you will probably find a link to his site.
Linson
Oct 24, 2025 02:00 PM
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
no green
Jan 9, 2016 09:22 PM
Royal_Z
Sep 30, 2015 08:45 PM
Dragonsys
Sep 25, 2015 03:51 PM
