BAD!!!
Old Oct 21, 2001 | 06:29 PM
L98IROCZ89's Avatar
Car: 1989 IROC-Z
Engine: 350 Vortech Supercharged ZZ4 TPI
BAD!!!
My car has really rough starts, and sometimes doesn't at all(just cranks 'till the battery dies). The fuel pressure goes down to where it is in the pic (0 psi) after the car is off for about 5-7 minutes.
What can I do about this, whats the problem?
1989 Chevrolet Camaro IROC-Z
L98 - 350c.i. TPI, rebuilt 700R4 auto w/shift kit, Dual catalyst Monza PaceSetter Cat-Back, SLP 1 5/8 Coated Headers, 3.23 Posi rear, Hypertech Thermomaster chip with 160stat, MSD 6A, March Under-Drive pulleys, AFPR, K&N's, !Air Box w/ Ram Air, moddified MAF, !TB Coolant, Spohn Dual Cat SubFrame Connectors, Alarm, Keyless entry, remote starter, 92 Z28 AeroWing, Brand New Paint (6/21/01)
Future: ZZ4 TPI w/EGR, T56, 3.42 or 3.73, Spohn strut tower brace and LCA's, Accell Universal 24# injectors
1989 Chevrolet Celebrity Eurosport <--DEAD AS OF 9/20/01
2.8 MPFI, no mods
225,000 miles and still ticking!
More info and pics on my webpage:http://go.to/iroc-z
AOL IMer: GPA 0point0
[This message has been edited by L98IROCZ89 (edited October 21, 2001).]
Old Oct 21, 2001 | 07:01 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
my guess is that your injectors are shot...
Check out MyGTA Nicknamed:The Big Red Machine
***AOL IM ClarkeMustGoNow***
Moderator at www.transamgta.com
"What does not kill us only makes us stronger"
Tony
Old Oct 21, 2001 | 07:04 PM
JETHROIROC's Avatar
Or fuel pump, or pressure regulator, or a relay. Does it hold pressure and then drop off quickly when you shut off the car? If so, then check the injectors, FPR and check valve to the pump. There's a diagnostic procedure you can follow to pinpoint which one that has been posted 100 times I'm sure. Do a search and you should find what you need.
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, MSD coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Accel 23# injectors, Holley module, ported plenum,
Ported Daytona Yellow stock base, Moroso valve covers, other stuff,
Streetdampr, Ruger P95DC, hot wife, new oil filter, !cats, !TBC, !AIR.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
Old Oct 21, 2001 | 07:17 PM
fly89gta's Avatar
Car: 2018 Camaro SS
oh yeah forgot about the check valve
Old Oct 21, 2001 | 11:14 PM
Vader's Avatar
Check this posting:
https://www.thirdgen.org/messgboard/...ML/004269.html
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
L98GTA87
Oct 19, 2015 10:43 PM
dimented24x7
Sep 17, 2015 06:58 AM
gta892000
Sep 16, 2015 12:40 AM
