Whats a good cam & head cobo for a 305 TPI motor?
Old May 4, 2008 | 12:42 AM
karl's-92'-z28's Avatar
Car: Too many cars
Im wondering what would be a good head & cam combo for a 305 TPI engine. Probably a wild street cam if possible, I have full length Hooker Super Comp headers & flowmaster supper 40's, yellow top injectors, & MSD that came wih the car. It sounds really nice just missing the heartbeat if you know what I mean
Old May 4, 2008 | 02:38 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Whats a good cam & head cobo for a 305 TPI motor?
Wild street cam + 305 + stock TPI computer = a very bad combination
There are only three good head choices for a 305 engine. L98 aluminum corvette heads (same as ZZ4 heads), or stock 305 TPI heads, or S/R Torquer 305 heads. And for a camshaft, unless you're planning on doing your own custom chips, you need to stick to something around 210 or less intake duration, with .470" or less lift, and 112 LSA or higher.
Old May 4, 2008 | 03:50 AM
Saculia's Avatar
Car: currently a 91 G92.
Engine: 305TPI
Transmission: Borg Warner WC 5 speed
I have the comp cams 08-500-8. It is 206 int 212 ex with a .480 int and .488 ex and 112 LSA. It works fine with the stock speed density computer, but will definitely benefit from a computer tune. This is with the stock TPI heads. It is a good torque cam.
Old May 4, 2008 | 06:09 PM
Car: Too many cars
I figured so, I have a 92Z 5.7 TPI all stock rite down to the muffler with 99*** miles on her, Im leaving her bone stock. So im in the process of buying another 92Z, but it has a 305 TPI & all of the emissions & a/c pulled.
So that will be my play car, it has ful length super comp hookers, super 44 flowmaster, mild trans, & suspension work. Getting it for a steal, so I was wondering what kinda cam & head would be good without doing major work.
I was looking @ AFR or Brodix heads if that would help.
Old May 5, 2008 | 11:58 AM
8T9 BANDIT's Avatar
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
crane 2032 + 113 heads..
Frozer!!!
Jan 19, 2024 04:55 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
st.evel07
Aug 13, 2015 06:15 PM
squiggy2
Aug 9, 2015 09:30 PM
drathaar907
Aug 6, 2015 04:20 PM
