Problems starting, stalling, New 350
Old May 4, 2008 | 06:39 PM
JN56's Avatar
Car: 1987 Formula 350
Engine: 5.7 350 TPI
Transmission: 700R4 w/ shift kit
Axle/Gears: 9 Bolt BW 3.27
Hello,
I just rebuilt a 350 and put it into my Formula and everything is okay except it doesnt start right away, it cranks for about a full 5 seconds or more before it turns over and finally starts. Once I get it started then it runs really good. Sometimes i have to turn the key 2-3 times for a couple seconds...
But the other thing is if I stop fast before it can shift back into 1st (its auto, 700r4) OR if I turn and brake at the same time, the RPMs fall so much it stalls.
I did the timing on it and that didnt work, oil pressure and temps are all good. I dont know what it could be, it ran fine before the rebuild and runs good now except the problems getting it started and it stalling if I dont pay attention.
Any ideas? It would help alot!
-Jesse
P.S. its a 1987 formula 350, 350 TPI, 700r4
Old May 4, 2008 | 07:02 PM
cwyates4's Avatar
Car: 85 vette/87 TA
Engine: built 383/350 tpi
Transmission: built 700r4s
Axle/Gears: 3.45 dana 44/ 3.27 9 bolt
Re: Problems starting, stalling, New 350
It sounds like your tps sensor could need adjusting. run a search on it, theres a thread that will tell you how to adjust it step by step.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
theshackle
Mar 5, 2017 06:37 PM
Wade787b
Sep 29, 2015 01:15 PM
92camaroJoe
Aug 13, 2015 06:07 AM
