looking for superram exp'd people pls
Old Oct 16, 2001 | 10:01 PM
quickL98's Avatar
Car: 87 trans am GTA
Engine: tesla permanent magnet
Transmission: 93 T-56
Axle/Gears: moser 12bolt w/ 3.73
ok here what happened, car blew hd gasket about 2 mos ago, got it running about a month ago and went to the track with the 58mm TB on it and ran a 14.2@96...WTF!!!!!
how do i go from 12.90's with a 48mm tb on superrammed motor to 14.2's!!!
i've tried several other chips, ecm's and looked it over with a scanner, the only changesmade when i got it runnig again were the bigger TB and a 140 amp alt. thats it, i can even run it a 12 deg base timng anymore with out serious spark kock @5k and up i dont what to, i was told to make it carbuerated and start having fun with the car and run faster too. i'm beginning to believe them , but i know this car run good with the efi , rough idle with 58 smooth start up and idle with 48 ? ed wright chip.
with the set up in my sig' what should this car be running? and what if i add 4.10's and a vigalante 3k stall ? thanks guys
87GTA ,10.5:1,4-bolt 355,afr 190's, super ram ,stock poerted base,58mmTB,24 lb FMS inj. ed wright chip, .510/230 (nr) 1&5/8 hooker shorty's, flow master single 3", 2800 ameri-torque non lk-up, 3.73. best to date with stk 48mm tb and lack of traction in 1st gear netted me a 12.9 @110mph /91 TA daily driver LB9 A4 2.73
Old Oct 17, 2001 | 01:17 AM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Your setup is identical to mine except I run a ZZ3 cam. If all you did was change a blown head gasket and nothing else, my first guess would be a vacuum leak on your SR especially since you said it idles rough. Why did you blow a head gasket? Did you check the condition of the rest of the motor? (compression test?) I don't think your bigger TB is responsible...I went to a 58mm TB from stock and went faster! How's fuel pressure? Weather conditions? I'd wait on putting in gears and torque converter til you figure out what happened. I'd stay with your 3.73s but use the Vig 3000 and ET streets.
1989 IROC-Z, ZZ3 shortblock with some bolt-ons.
13.20 @ 108.69, 2.2 60'
Old Oct 22, 2001 | 11:50 PM
quickL98's Avatar
i believe the culprit showed himslef the other day in regards to my performance issues, my car seems to have beaten to death a stock converter, which would explain the shuddering evry time i gave it gas, and the slowly elated stall speed overtime, which peaked at 3200!!!
from a stock 11" converter.
what does your car run with the setup you have?
Old Oct 23, 2001 | 08:44 PM
IROCZZ3's Avatar
Car: 87 Buick GN
<font face="Verdana, Arial" size="2">Originally posted by quickL98:
</font>
See sig...
Glad you found your problem. Time to get that Vigilante!
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Pac J
May 17, 2020 10:44 AM
LC2 TECH
Oct 13, 2015 11:53 PM
MadOTC
Oct 13, 2015 04:46 PM
