Idling Problem
Old May 6, 2008 | 07:15 PM
mitchcoxkc's Avatar
Car: 1962 Chevy Nova
Engine: 383 TPI
Transmission: 350 Turbo
Idling Problem
I have a 383 with Dart Pro 180 72cc heads on top of flat top 2 valve relief pistons with a Comp Cams XE 262 hyd camshaft and a 88 TPI unit in my 1962 Nova. I am using 24 lbs injectors 58mm Holley throttle body. When I start the car the idle comes up and will not settle down until it idles for 5 minutes or so.
Any help???
Thanks Mitch
Old May 10, 2008 | 09:02 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Re: Idling Problem
Checked the IAC?
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
perZ
Aug 15, 2015 01:17 PM
