? about code 42,43
Old Oct 25, 2001 | 08:58 PM
dacuma's Avatar
Car: 89 Irocz
Axle/Gears: 342
? about code 42,43
Alright fellows I just did an engine swap, not to long ago and I m in the process of tunning it. Well anyway I got the codes 42,43 it only comes up when I get on it. But it only started after I adjusted my TPS, My TPS is bumped up .72 volts though I was going for .70 and had it there but when tighting I guess I bumped it. Well anyway cause I went over the max, would that be causing the prob? Thanks guys.
Old Oct 26, 2001 | 07:53 PM
Earl 87gta's Avatar
I think code 42 and 43 is an electronic egnition code usaly the problem is from the little brown wire that runs to your distibuter that you undo to time the engine check it and see if it has a good conection and it will probably go away.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
