MAS AIR FLOW?
Old Oct 25, 2001 | 05:39 PM
85wilrocu's Avatar
MAS AIR FLOW?
My car was running rich and not idling very well, so I took it to my mechanic and he pulled the maf plug out and the damn thing reved like a *** damn monster!? He said that I don't need it. Its just for smog purposes!?
So the ? is do i need one or what?
1985 Iroc Modifications:
Ram air,K&N filters,Mas Screens off, fins taken off,52 MM Throttle body,
Corvette servo,B&M Transmission shift kit,
Flowmaster exhaust system
March Performance pulleys
Hypertech super coil.
Fords are Like Tampons, Every PU$$Y Has One!
Old Oct 25, 2001 | 05:58 PM
camaro6spd's Avatar
WHAT!!!!
the MAF just for SMOG, get a new mechanic. The MAF tells the computer dow much air in entering the engine and the computer then adds fuel accordingly
1987 Black 305 TPI 5spd IROC, seems to be fully loaded, but can't find RPO codes.
AIM: IROC 5spd
http://www.geocities.com/chevy5spdiroc/87Roc.htm
Old Oct 25, 2001 | 06:02 PM
85wilrocu's Avatar
Soooo do I need a new maf or what?
Old Oct 25, 2001 | 06:09 PM
BitchinCamaro's Avatar
HAHHAHHAHHAHHAHA... (like camaro6spd said) do NOT go back to that mechanic, he obviously knows NOTHING about computer controlled cars. Your MAF may or may not be the problem, give us some more details on whats going on with your car.
Old Oct 25, 2001 | 06:14 PM
85wilrocu's Avatar
THE CAR RUNS FINE NOW WITH OUT IT?
Old Oct 25, 2001 | 06:28 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
IF it runs better without it, then there is certainly something wrong. Does it set a code? (with it unplugged, it should leave the SES lite on solid.)
Old Oct 25, 2001 | 07:22 PM
Vader's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 85wilrocu:
THE CAR RUNS FINE NOW WITH OUT IT?</font>
Um... I don't think so. Have you checked your fuel mileage since it has been unplugged? Have you looked at the plugs? Is your oxygen sensor trashed yet?
You really need to find the solutions to the two problems you have:
* Fisrt, scan the ECM for error codes. That should provide some information about the problem. If your "mechanic" disputes the idea that the MAF is a necessary sensor for more than just emissions control, ask to see his ASE certification;
* Second, start asking around for a mechanic that actually has some skill with fuel systems. There are a lot of "mechanics" that are very good with chassis problems, general engine and exhaust work, and maybe even some electrical problems, but are clueless when it comes to fuel systems. Damn! After all, these systems are almost 17 years old! Apparently, your "mechanic" hasn't been staying even close to current with automotive technology, and shouldn't be making such sweeping statements without having a little more information.
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
Old Oct 26, 2001 | 04:14 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
LOL, thats crazy!!
89 RS
STILL Looking For:
An 87 IROC-Z28 350 TPI
Yeah I have an RS, but I want an IROC-Z!!
Old Oct 26, 2001 | 11:53 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
YES, YOU NEED THE MAF!!!!!!! Never and I mean NEVER go back to that mechanic! If you car is running better without the MAF plugged in then there is a big problem. Plug the MAF back in and then let use know what is going on. WE, not that mechanic (and it hearst me to call someone like that a mechanic), will help you out.
Now I HAVE_A_Z
89 IROC 350 TPI
Old Oct 26, 2001 | 12:10 PM
85wilrocu's Avatar
So should I go and get a new maf or should I keep my eyes peeled on the board for a good used one? By the way I don't have a scanner, but I think now im going to invest in one.
Thanks alot fellas!
Old Oct 26, 2001 | 07:45 PM
Earl 87gta's Avatar
Before you replace the mas you need to plug it back in un hook the baterry clear all the codes take it to the first wall mart or auto zone pepboys what ever by the time you arive the codes will be back buy a cheap gm code breaker from one of the places above for $20 or spen $200 for a cheap scan tool on line then check the codes it will tell you how to do it. You will probly have three codes if the problem is being coused by the mas one will be the mas one will be the mas burn off relay and the last will be mas power relay the to relays are only 10 for the burn off 15 for power and they are next to the fuel pump relay so instead of trying to determin wich one is the fuel and with is the burn off you may want to just change them both if this does not clear those codes then break out 180 for a reman mas at auto zone. I have had these codes three times and have only replaced the mas once the other two time it was one of the realays.
Old Oct 26, 2001 | 10:40 PM
Vader's Avatar
Instead of a "cheap" $20.00 code scanner, I'll sell you one for $5.00 plus postage. Or you can go out and find your own for next to nothing.
The kind I sell looks amazingly like a regular paper clip cut in half, but WE all know it as a "G.M. Stored Diagnostic Trouble Code Retrieval Device". Call it whatever you want, I'd be glad to mail one to you for five bucks.
If you decline, I'll make you read the following file to get the error code definitions on your own:
GM Error Code.pdf
You'll need Adobe Acrobat Reader to view/print the file (see below).
Later,
Vader
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
scotrans am
Sep 5, 2015 04:26 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
