Air pump delete affect MPG?
Old May 10, 2008 | 01:53 AM
maitlandtron's Avatar
Car: 1985 Z/28
Engine: L98 Carbed
Axle/Gears: 9 Bolt Posi 3.45
My air pump locked up and broke the belt recently. I have been driving it like that for a couple weeks because I haven't gotten around to replacing the air pump. I have noticed that my MPG has gone down drasticaly. Could this be related to the air pump not running?
Old May 11, 2008 | 12:51 AM
Car: 1985 Z/28
Engine: L98 Carbed
Re: Air pump delete affect MPG?
bump
Old May 11, 2008 | 10:50 AM
Abubaca's Avatar
I'm not going to say anything is 100%, but in my experience, no, it's not going to effect anything. I removed mine and had no change in mileage.
Old May 11, 2008 | 10:55 AM
riphc06's Avatar
Car: 89 Camaro RS
Engine: 350 TPI L98
Transmission: 700r4 w/ shift kit and 2500 stall
Axle/Gears: 2.77 one tire fire!!
This should not have a noticable affect on your milage. I have read about a 100mv offset in your o2 sensor, that is programmed into the ECM to make up for the fresh air being pumped into your exhaust, therefore it could affect your A/F ratio However, 100mv is a VERY small amount. Furthermore, it only comes into play during certain, uncommon driving conditions. I would start looking for a leaky injector or something else. Good luck.
Old May 11, 2008 | 11:17 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Buy, borrow a working pump see if mpg goes back up and let us know. Mine was removed prior to me, and mpg are 15 town 20 trip with a stock OEM chip.
Old May 13, 2008 | 12:40 PM
Chrisry1995's Avatar
Car: 89 Trans-Am
Engine: 5.7 TPI
If you look for air pump delete you will get MANY opinions on the subject. I removed my air pump for thae same reason you did and it didn't affect my gas at all. It maybe even went up just a tad. Motor wasn't turning an old half frozen pump. I went a step further. I installed the Hooker headers/Y-pipe and now my engine-bay is SO much easier to work in without all the tubes and diaphams...etc. Best money I ever spent. MPG was 21MPG with 5.0 tpi and after swapping with 5.7tpi from same year GTA into my Trans-am and pulling the air stuff off, I now get 20mpg. Luckily I live in Michigan and don't have to worry about smog test. It seems the 20 mpg. is what people here are getting with the 5.7 and alittle better with 5.0. Make sure you routed belt correctly and water pump turning oppisite of everything else. I also swapped my motor because I had starting problems. Found my injector coils read from 2 ohms to 12 ohms.(should be all the same) That's a quick check to see if they are O.K. electicaly..BTW.
italiano67
Dec 11, 2016 09:21 AM
InfinityShade
Aug 22, 2015 08:00 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
mcquigg
Aug 13, 2015 02:26 PM
drathaar907
Aug 6, 2015 04:20 PM
