Are there differences between TPI setup for a auto tranny and man. one
I've got an 89' Firebird with the 2.8ltr MPFI and 700R4 tranny. Pulling V6 and dropping in a 5.7ltr TPI and want to use a T-56. Will there need to be any changes to the enigne electronics or harnesses when going from an auto. tranny to a manual one? Exspecially a T-56? The TPI is from a 91' and I don't know if it was a auto or manual.
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
My Guess would be you could safely run the Automatic chip in a manual. The Manual chip though has no control over the Torque Convertor for automatics.
Your best bet would still be to start burning, It is cheeper to get up and burning than to buy an aftermarket chip.
John
John
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
<font face="Verdana, Arial" size="2">Originally posted by okfoz:
</font>
</font>
Check out MyGTA Nicknamed:The Big Red Machine
***AOL IM ClarkeMustGoNow***
Moderator at www.transamgta.com
"What does not kill us only makes us stronger"
Tony
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I'm running an auto chip with a 5 spd. No SES light..
Its not the _best_ chip in the world. It only advances to like 24' total timing, and madmax is right, you should start burning your own chips..
BUT, you will be fine for now. I am.
-- Joe
1989 Formula 350 4-bolt
mains, Forged .030 TRW
pistons, SLP 51010
Roller Cam, Comp-cams roller lifters, Summit 1.5 roller rockers, World
Products Sportsman II
2.02/1.60 heads
Edelbrock TPI Intake
24lbs/hr Injectors
Cloyes Double Roller
timing chain, Comp Cams
roller lifters: 13.5 @
100.23 MPH
-- Joe
-- Joe
pistons, SLP 51010
2.02/1.60 heads
24lbs/hr Injectors
100.23 MPH
-- Joe
Sanjay
Aug 12, 2015 03:41 PM
