Oxygen sensor reading says low all the time. WHY?
Old Oct 30, 2001 | 08:43 AM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
I checked a oxygen sensor reading last night and it was fluctuating between 300 and 450mv. I never went up. The car has been warmed up.
What does it mean? I ahve an AFPR set at 42Psi with vacuum hose attached.
i have repleced this sensor 1.5 year ago with the OEM replacement called NIEHOFF.
Can anybody suggest something.
Should I install my old sensor and see what happens?
Thanks.
89Iroc, 305 TPI, WC T5, 3.08 Posi, Headers, Hooker Y-Pipe, 3 inch over the axle, Flowmaster 80, No Cat, Aluminium Driveshaft, Ported Plenum, Air Foil, K&N, All free mods,
Old Oct 30, 2001 | 08:52 PM
Vader's Avatar
D,
Either the exhaust is very lean, or the sensor is not getting hot enough, or the sensor is failing. It would be fairly easy to swap back to the old one as a comparison.
To make sure you are not running artificially lean, check the A.I.R. system diverter valve and check valves. A leaking diverter can dump excess air into the exhaust, causing a false lean reading of the O2 sensor (low O2 voltage).
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
Old Oct 30, 2001 | 10:05 PM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
Thanks Vader for the reply.
I have removed the AIR crup long time ago so it would not be it.
Would't the ECM stay in the open loop if the oxygen sensor was not warming up?
I am going to put my old one in to see what happens.
Maybe is not warming up because of headers.
bamaboy0323
Sep 3, 2015 06:07 AM
mdtoren
Aug 23, 2015 12:52 PM
beast94
Aug 20, 2015 06:44 AM
mdtoren
Aug 16, 2015 05:45 PM
mizz0313
Aug 12, 2015 06:45 AM
