car dies at a red light
Old May 12, 2008 | 05:31 PM
83' maro's Avatar
Car: 1987 IROC-Z Camaro
Engine: LB9 305, edelbrock intake.
Axle/Gears: 10 bolt, 3.73 posi w/ disc brakes
Well I just got my 87 IROC on the road. I have noticed after about 15 minutes of driving the car will get a SES light and the code is 44 for lean oxygen sensor reading. now I'm hear a particularly loud ticking noise coming from the injectors. Now I know that the injectors are supposed to be noisey and know for their ticking but I just have a feeling that my car might be dying at a stop at times because of a bad fuel injector? Any opinions would be awesome!
Old Jul 14, 2008 | 09:39 AM
kfuss's Avatar
Re: car dies at a red light
Did you ever find the problem for this?
I am having the exact same issue.
Thanks,
Kirk
Old Jul 14, 2008 | 11:19 AM
83' maro's Avatar
Actually Kfus I just fixed it yestarday! I yanked out my ICM (ignition control module) put in a new one. then I redid the timing and set it for 6 degrees. After I reset the ECM and it hasn't died once at a stop or a red light. Definitly try that if you got about $40 to shell out.
Old Jul 17, 2008 | 08:59 AM
kfuss's Avatar
Thanks for the reply, and congrats on finding the problem, I know that feels good.
I have changed that out, but I did not change out the knock sensor to go with it, I will try that next.
Old Jul 17, 2008 | 09:42 PM
IROCthings's Avatar
Car: 85 335IROC Camaro
Engine: 335 tune port
Transmission: 700r4 Stage 2
Axle/Gears: 3:73
hey 83 maro how did you go about doing what you did. did you replace the ecm and in explanation form what exactly did you do. i've stressed so many options i'm startin to feel like a 'tard.
Old Jul 18, 2008 | 09:06 AM
kfuss's Avatar
Found my problem, like usual it was a simple thing. My PCV valve hose had a split at the manifold, causing a vacuum leak.
Thanks!
Wade787b
Sep 29, 2015 01:15 PM
justin57
Aug 20, 2015 07:05 PM
Omega
Aug 10, 2015 12:46 PM
