Another 1987 IROC 5.7l MAF Question....
Old Oct 26, 2001 | 08:06 PM
72Blazerod's Avatar
Hi guys,
First off I want to thank you all so much for helping me out with info all this week!!! Okay now for the problem. I just found out that the IROC 5.7l engine I was going to pull this weekend is missing its MAF unit (thanks again for all your help on that!) Now my questions are, should I buy the motor any way? Where would I get a MAF unit for an '87 5.7l? How much should I pay? Does anyone have one? How can I tell if I get the right MAF (is there a serial number for an '87 5.7l)?
Again, any info is muchly appreciated!!!
Thanks again,
Rod
Old Oct 26, 2001 | 09:45 PM
Earl 87gta's Avatar
New they are almost 300 but auto zone and advanced auto sell them for 180 reman dont know how much you are paying for the hole engine and harness but a tpi set up with every thing sells for around 500 with out the engine on line and then you end up having to change the mas any way half the time.
Old Oct 26, 2001 | 10:31 PM
Vader's Avatar
72,
You can get a brand new, warranted Wells SU-145 MAF for your engine for about $170.00 (US). They are a lot more reliable and durable than the OEM style hot-wire MAF, and flow better. They use the same thick-film sensing technology that the newer LT1 and LS1 engines use, whereas most aftermarkets and all remans used the hot wire sensor. I've got two years+ on mine without a problem.
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
Old Oct 28, 2001 | 11:33 PM
Kevin 88's Avatar
Car: 88 Corvette
Engine: 400, AFR heads, ZZ9, SuperRam, 730
Transmission: Slushbox
Vader,
Where did you get your Wells MAF?
Old Oct 29, 2001 | 12:46 PM
Drakar's Avatar
YA, I need a new maf and they are 250-600 $CAN, so 170 yankee for the best MAF for TPI, is a steal.
can we order online, or should I make a road trip down state side to get one at an auto store???
1989 Trans Am GTA
Old Oct 31, 2001 | 09:31 AM
leirch's Avatar
Guys,
I swapped my 87IROC over to Speed Density early this year, I have the ESC module and a near new Wells MAF sensor just laying around if anybody wants them...
PS.
Didn't intend for this to be a classified ad, just trying to help somebody out.
Brendan
1987 IROC-Z L98,SR,EB 6085's,LPE 219/219 Cam, Crane 1.6RR, EB TPI Base, 58mm TB, Stock T5, 30lb SVO, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, Aluminum DS, 94 Disk Rear, Adjustable Prop Valve, Precision 3.73 Gears, Weld in Sub-Frame Connectors, Hotchkis LCA's, KYB Shocks/Struts, Poly Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm, Big stereo, 730SD Conversion.
To see the ROC, Check out the webpage Here
Old Oct 31, 2001 | 09:58 AM
Desert86Roc's Avatar
Wells Model # SU-145
You can get one through: World Discounts (800) 288-6728
Another good thing about the Wells....Lifetime Warranty!
Mike Metzler (Desert86Roc)[*] Check Out:SpeedWorldMotorplex.com[*] Check Out:Chevrolet F-Body Online Part & Illustration Manual[*] www.MetzlerRacing.com
Best ET @ 1250 ft[*] 15.352 @ 91.215 mph (uncorrected)
Old Oct 31, 2001 | 02:49 PM
JR4444's Avatar
I've got two used MAF from an 88 and 89, If anyone is interested let me know.
Out-Cast
Dec 31, 2015 04:40 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
g.l.mos
Aug 22, 2015 12:02 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
Out-Cast
Aug 17, 2015 10:57 AM
