throttle getting stuck slightly open at idle
Old May 12, 2008 | 11:17 PM
dspencer24's Avatar
Car: 91 z28
Engine: 350/ported accel tpi/AFR 195
Transmission: t-5 =(
Axle/Gears: 345
When i rev lightly the throttle body gets stuck open a lil bit i have to rev hard or push it back into the stop how can i fix this so it doesnt do this everytime? its causeing my high idle
Old May 12, 2008 | 11:57 PM
vasquezmrysvll's Avatar
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
Re: throttle getting stuck slightly open at idle
look into reseting your IAC valve and TPS, the spring for the throttle "butterflies" is pretty stout. i kinda doubt its getting hung up, unless your TB is EXTREMLY gummed up. in that case remove the tb and clean it up with carb cleaner.
Old May 13, 2008 | 12:18 AM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
i figured it out sorry for the post guys it was my cruise control it was to tight so i moved it alil..
Old May 13, 2008 | 06:48 PM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
well that fixed my problem a lil bit but my throttle still gets stuck alil sometimes unless i rev hard
Cameeeero
Sep 18, 2015 04:00 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
