Vacuum leak/erratic idle only when cold?
Old Oct 30, 2001 | 10:54 AM
Reno's Avatar
When it's cold, I get about a 2-300 RPM varience (settles down, pops up, settles down, pops up, 5 second cycle or so). After it warms up, steady as can be.
Any suggestions?
-Reno
89 Formula 350
"This is how you remind me of what I really am..." - Nickelback
Old Oct 30, 2001 | 08:29 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
check the temp sender going to the ECM. Its located in the front of the base.
Mine would idle irradcally until it warmed up, that was the problem, the sensor was on its way out.
John
Old Oct 30, 2001 | 09:03 PM
82resto's Avatar
The front of the base? You mean the intake manifold?
Jon
89 GTA
Beautiful Gunmetal gray, LB9 305 and T5 tranny. Only 60,000 miles!
Dual cats, 3"flomaster
Accel 300+ Ignition, wires, cap, coil, etc
Airfoil
KN Airfilter
Removed Screens on MAF
SLP 1 3/4 headers
No Smog/AIR system
Old Oct 30, 2001 | 10:39 PM
breathment's Avatar
yes, its located in the front of the intake manifold, however, iv heard of a slight intake leak or gasket leak could cause ur symptom, when the engine heats up, the metal expands and kinda seals up the hole.
have u checked ur vacuum?
the CTS could also very well be the problem, id check both.
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
http://www.geocities.com/david_angel_16
Old Oct 31, 2001 | 10:30 AM
Reno's Avatar
here's where I suck... What's a CTS, and what SHOULD my vacuum be at idle?
-Reno
"We are the middle children of history. Our Great War is a spiritual war, our Great Depression is our lives" - T.D.
Old Oct 31, 2001 | 04:25 PM
breathment's Avatar
CTS coolent temp sensor. vacuum, im not sure about, mine is around 19" i think, just check it when u first start it, and when its warm and compare.
- David
jklein337
Sep 19, 2018 06:23 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
86CamaroDan
Sep 29, 2015 10:08 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
