MAP location
Old Oct 24, 2001 | 11:21 PM
87_350_Z's Avatar
MAP location
I'm setting up a SD system using a MAF
plenum with no MAP boss. What/where
is the best method/location for mounting
the MAP sensor?
TIA,
Jack
Old Oct 25, 2001 | 01:17 AM
airdeano's Avatar
firewall, make a bracket, no limitations on
where other than how long the wires and
vacuum hose are. just want a full manifold
vacuum on that line. DO NOT TEE OFF THE
MAP
airdeano
Old Oct 25, 2001 | 04:30 PM
kevinc's Avatar
Car: 1982 Z28
I noticed the carbureted 3rd gens and some V6 injected models have a stamped steel bracket that bolts to the firewall lip, under the bolt that holds the brace bar that goes from the firewall to the fender.
For a pic see:
http://www.eecis.udel.edu/~davis/z28...installed2.jpg
Go shopping, should have no problems finding these at your local junkyard.
1982 Z-28
See http://www.mycar.net/mafb/registry/detail.cfm?id=276 for details
Old Oct 26, 2001 | 02:56 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
It should be placed hogher than the vacuum hose from the plenum to avoid condese to get into the MAP sensor.
GTA -89:383, 4-bolt,Free flow muffler,dual 3" HF cats, Edelbrock headers, Canfield heads, 1.52 RR 7/16, ZZ-9 cam, Big Mouth, AS&M LTR, !plenum, 52 TB, MSD 6AL, TPIS level V prom, Superior shift-kit and all the minor mods,looking for a SR ...
http://www.itv.se/tacs/members_cars/m279/m279.html (Swedish Trans Am Club)
Old Oct 31, 2001 | 11:31 PM
87_350_Z's Avatar
Thanks for the info.
Jack
'87 Z28 350 4bolt CompCams roller everything,
TPI conv in progress.
topteam54
Oct 6, 2015 12:21 AM
ULTM8Z
Sep 16, 2015 09:15 AM
sandman92084
Sep 12, 2015 10:27 PM
Jlanz55
Sep 6, 2015 02:35 PM
tonys91rs
Sep 2, 2015 07:07 PM
