Injectors Questions
Old Oct 29, 2001 | 08:42 PM
IROCKER's Avatar
Injectors Questions
Well I believe my injectors are starting to go south so I would like your opinions are what you feel are the best injectors to get.
Also, do the runners have to be removed to replace the injectors? I plan on porting my plenum over the winter and if I can remove the fuel rail to get at the injectors without having to remove the runners as well then that is a big bonus.
1987 Camaro IROC-Z
350 TPI (L98), HyperTech Airfoil, K&N Filters and modified airboxes, AC Delco RapidFires, Taylor SpiroPro 8mm wires, Energy Suspension polyurethane bushings for front and rear LCAs and sway bars, KYB struts and shocks, BFG g-Force Z-rated tires, MAC STB, MAC SFCs, JET low temp stat, CarSound Hi-flow Cat, 3" Mandrel-bent pipes, Flowmaster muffler, Corvette Servo, TransGo Shift Kit, Corvette 2000 Stall, TruCool LPD tranny cooler, T-tops.
2001 Sunfire GT
2.4L, 5-speed, K&N cone filter, interior detailing, 200W Monsoon Sound System (8 speakers), Silver Metallic exterior with grey interior.
Web: http://www.angelfire.com/on3/whitelightening
Old Oct 29, 2001 | 08:48 PM
Vader's Avatar
Check this link:
Cruzin' Performance
For less than the price of one stock injector, you can get your entire set cleaned, flow matched better than most aftermarket "matched sets", and have new 'O' rings and screens installed. It takes about two days in their shop to do the entire job. Ship them next day both ways, and your "new" injectors can be at your door in less than a week.
I've used them and have had very good experiences each time.
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
[This message has been edited by Vader (edited October 29, 2001).]
Old Oct 30, 2001 | 08:48 AM
IROCKER's Avatar
Thanks Vader...I've been meaning to contact them.
1987 Camaro IROC-Z
2001 Sunfire GT
Old Oct 30, 2001 | 11:44 AM
nblanchard's Avatar
What if an injector has a low resistance? Will they repair it?
<font face="Verdana, Arial" size="2">Originally posted by Vader:
Check this link:
Cruzin' Performance
</font>
1988 Pontiac Trans Am GTA L98 5.7L, Black on Black with 114,000kms.
Custom 3" Stainless Exhaust Y-Pipe back (High flow Cat and Flowmaster Mufler)
Old Oct 30, 2001 | 03:58 PM
Mojo's Avatar
<font face="Verdana, Arial" size="2">Originally posted by nblanchard:
</font>
I'm not sure, but if you have to buy a new set I'd recommend the Ford Motorsport injectors for the price. I'm using a set of the FMS 30# injectors in my Vette.
408cid 1985 Corvette
http://www.mojosgarage.com
Old Oct 30, 2001 | 08:14 PM
palric's Avatar
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
Just a few words on the injector business. Cruizin Performance is a good deal as long as you don't use the 89-92 Rochester Multec style injectors (305 and 350). They won't rebuild these injectors, I know cause I just went through the drill with them.
If your resistance is reading low on your injector(s)then your injector is toast. This is why I am replacing two of mine. The Multec style injectors are known for this problem.
Regarding replacements, I just bought 8 19lb injectors off a low mileage 91 Z28 for $50 through the classified pages on this board. When they arrived I had them tested and they are all within spec -- good deal for me cause these injectors would cost about $1200 for 8 here in Canada.
RP.
'91 Formula Firebird G92,WS6,5-speed,3.42 a ton of fun to drive.
Old Oct 31, 2001 | 02:47 PM
IROCKER's Avatar
Expensive YES! THe GM dealership is insane wanting as much as they do for them. That's why I want to inquire about aftermarket.
Another question: The average resistance for my injectors was about 16.7 when cold and about 17.3 when warm...Is this high or low?
1987 Camaro IROC-Z
2001 Sunfire GT
Old Nov 1, 2001 | 07:17 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
The resistance looks to be in the right range to me. The next step would be to remove the fuel rail from the engine (with the injectors still attached to the fuel rail), prime the fuel pump (turn ignition to On, but don't start the engine), then see which ones are leaking.
Greg Westphal
'87 IROC 355TPI/A4
Old Nov 1, 2001 | 08:22 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
how can you tell the difference between multec injectors and the regular type injectors(bosch,rochester?) the ones in my 88' look different from the one's in my 89'.
86',88',89' IROC-Z, 350 TPI, 700-R4
94' Formula, LT1, 6spd
Old Nov 1, 2001 | 05:16 PM
Mojo's Avatar
<font face="Verdana, Arial" size="2">Originally posted by palric:
RP.
</font>
Good *** !! $1200!!! I paid $200 for my 30# Ford Motorsport injectors through Summit.
MustangBeater20
Oct 29, 2022 09:20 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
ezobens
Aug 19, 2015 10:29 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
