TPI porting.. which areas to work on?
Old May 14, 2008 | 01:16 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
What areas should I work on when porting my factory base? What areas need the most improvement? Is there anything I can do with the factory runners? They seem quite thin.. What about the plenium? So far I've smoothed out the egr walls and around the throttle bores, what else needs work?
Old May 14, 2008 | 09:16 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: TPI porting.. which areas to work on?
gasket matching the heads and intake is essential
dont gasket match unless you do the heads too, you do not want the intake passage to be larger than the head passage
Old May 14, 2008 | 12:18 PM
klause83z28's Avatar
Car: 83 z28
Engine: boat anchor 305 (ex CFI)
Axle/Gears: 3.23 10 bolt
Most of the time the baseplate is the one people go after first. The plenum comes next. As for the runners most people just buy slp or edelbrock pieces, the stock ones are really not suitable for porting. There are people on the boards here that have done it, and the gains are not nessasarily the HP, but the powerband is extended past the infamous 4500. I would do it, but I am really heavy handed and would end up grinding way too far. Someone should port tpi manifolds for money!!!
Cheers!!!
1992rs/ss
Jan 31, 2025 05:10 PM
Vintageracer
Jan 10, 2020 05:33 PM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
