are these stock injectors?..pic inside
Old May 14, 2008 | 08:57 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
I did a search and I cant find and answer either way if blue and silver injectors are stock or not. On a 91 305 tpi S/D. thanks
Old May 14, 2008 | 11:36 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Re: are these stock injectors?..pic inside
That looks like a GM injector. As for if it's the stock injector for that car, I can't say.
Old May 14, 2008 | 08:36 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
anybody know for sure or have other guesses. thanks.
Old May 14, 2008 | 09:29 PM
1987ZTPI's Avatar
Car: 1987 IROC-Z
Engine: 310 lb9
Transmission: SEMI STOCK 700R4
Axle/Gears: 3.45 9 BOLT
Looks like the GM multecs they are chevy injectors and they came on camaros but i think they are 21lb injectors, 5.0L should be 19lb.
Old May 14, 2008 | 10:52 PM
Abubaca's Avatar
From the picture I can say they look EXACTLY like the stock 22# GM Multecs I used to have in my L98.
What those are, their rating, how old they are.......I can't say.
Old May 15, 2008 | 04:26 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
wouldnt 22# injectors make a 305 speed density motor run like crap?
Old May 17, 2008 | 10:26 PM
jimchristiansen's Avatar
Car: Jeeps
Engine: 1970 4 bolt 350, 19000 miles & TPI
Transmission: Tubo 350
Axle/Gears: 4:11
To be sure you could check the numbers, but they do appear to look the same as my 22# GM injectors. Here is a pic of mine- one is a newer change up but still 22#.
I'm giving the numbers here for you, too. Hope this helps. Jim
Attached Thumbnails are these stock injectors?..pic inside-two-different-injectors_640.jpg
italiano67
Dec 11, 2016 09:21 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
gta90
Sep 15, 2015 04:00 PM
z28_AJ
Aug 27, 2015 08:59 PM
ezobens
Aug 19, 2015 10:29 PM
